Voltage Regulator...How Warm?
Old Jun 22, 2016 | 09:10 AM
grbrown's Avatar
grbrown
Cool
Originally Posted by Yankee Dog
One thing I did notice while running the Dr. Hess diagnostic, the higher the RPM's (and higher voltage output around 14.6), the warmer the regulator got. At Idle (around 13.6 volts), the regulator felt cooler. Makes sense and is just an observation.
Sounds as if it's doing its job as designed! It is dumping the surplus electrical energy as heat. While moving the temperature of it will be lower, thanks to air flow. Sometimes it doesn't pay to get too inquisitive!
Old Jun 22, 2016 | 06:45 PM
GraemeR's Avatar
GraemeR
Thats why the regs are made with fins and normally installed up front so they get airflow. They do make a fair bit of heat!
Old Jun 22, 2016 | 06:55 PM
TriGeezer's Avatar
TriGeezer
Don't worry about it, if it's working.
Oh yeah...don't even think about putting a cover over it. Heat sink grease or not, the cover will not dissipate the heat.
Old Jun 22, 2016 | 08:54 PM
Hey Man's Avatar
Hey Man
It's used in the electronics industry. It is a paste used to conduct heat away from electronic components to a heat sink.
Thanks.
Even the ones that are open in the front?
Old Jun 22, 2016 | 09:02 PM
TriGeezer's Avatar
TriGeezer
Originally Posted by Hey Man
Thanks.
Hard to tell, but I wouldn't do it. However, the worst that will happen is that a $150 regulator will fail. If it fails in the most common mode, you get no charging of the battery, and you get a dead battery. In the other, but less likely failure mode, you get unregulated voltage on the battery and all the electronics. That can be ugly.
Dave Bell
Aug 10, 2016 10:20 AM
hellboyrich
Mar 6, 2011 11:52 AM
icehead2
Jul 27, 2010 03:59 PM
diiulio
Apr 22, 2010 04:01 PM
timberwolfz28
EVO
Jun 25, 2009 09:05 PM
