Wheel Bearings
Old Jun 25, 2016 | 02:21 PM
Beemervet's Avatar
Beemervet
Default Wheel Bearings
OK...
My built rear wheel, Indian rim laced with stainless spokes to a HD hub had some broken spokes, had it repaired once and the second time it happened (on the road) I replaced it with a crappy looking mag. I bought a 2004 9 spoke wheel which has 1" sealed bearings. I already had the proper pulley and will soon have the rotor. Looking around I think I've found bearings that will reduce down to the 3/4" axle as well as reducer bushings that are used in the 1" bearings to use the 3/4" axle.
Anyone here have any experience doing this with their EVO?
(And no Graham, I don't want to go with the newer swingarm)
Old Jun 25, 2016 | 02:26 PM
Stiggy's Avatar
Stiggy
My '00 RG has 1" sealed bearings front and 3/4" sealed bearings rear and as far as I can see, they are interchangeable.
Old Jun 25, 2016 | 04:00 PM
langwilliams's Avatar
langwilliams
I'd like to know about those adapters too, it would open up the use of a lot of wheels.
Old Jun 25, 2016 | 06:00 PM
Beemervet's Avatar
Beemervet
Old Jun 25, 2016 | 06:08 PM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by Beemervet
OK...
Both work..if you use the bearings, you will have make an inner spacer...if you use the reducers you have to have custom spacers...which you probably will with the bearings too..no biggie either way...the reducers are easier IMO.
Old Jun 26, 2016 | 08:01 AM
WP50's Avatar
WP50
I may have missed it but why would a different inner spacer be needed when using the bearings?
Tapered going to sealed bearings.
Umm Bearing thickness different?
The spacers I get
Thanks
WP
Old Jun 26, 2016 | 08:15 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by WP50
I may have missed it but why would an inner spacer be needed when using the bearings?
Umm Bearing thickness different/
The spacers I get
Thanks
WP
The inner spacer goes between the bearings and it allows you to set preload on the bearings.
Old Jun 26, 2016 | 08:49 AM
WP50's Avatar
WP50
Preload on a sealed Bearing???
WP
Old Jun 26, 2016 | 11:53 AM
Stiggy's Avatar
Stiggy
When you crank 55 lbs tq onto the axle nut, there must be an inner spacer between the bearings so that you don't destroy them. It fits right up against the sleeve that touches the axle inside the wheel.
Old Jun 26, 2016 | 03:47 PM
WP50's Avatar
WP50
Originally Posted by Stiggy
Whwn you crank 55 lbs tq onto the axle nut, there must be an inner spacer between the bearings so that you don't destroy them. I fits right up against the sleeve that touches the axle inside the wheel.
Edited post Thanks
