1997 Ultra classic starting problem
Old Aug 5, 2016 | 07:09 PM
Meastly's Avatar
Meastly
Default 1997 Ultra classic starting problem
I have a 1997 Ultra classic, fuel injected, never really had a major problem until now. About 80% of the time it will start right up after one crank, the rest of the time it will crank over and over and over but never start. When it doesn't start it could start as soon as 10 minutes later, sometimes not for hours. When it won't start if I remove the plugs they are dry, and the plugs were changed. The fuel pump is working fine, the fuel filter was changed... Not sure what would cause it to just randomly not start... Any help would he appreciated.
Old Aug 5, 2016 | 07:12 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Have you checked for spark during one of the non starting times?
Old Aug 5, 2016 | 07:17 PM
Meastly's Avatar
Meastly
I have not checked spark, when it wouldn't start and I noticed the plugs were dry I assumed it wasn't getting gas. That's what led to me checking the fuel pump and changing the fuel filter.
Old Aug 5, 2016 | 07:33 PM
texashillcountry
Dirt don't hurt
I'd check for spark first and rule that out.
The resident expert on FI systems is "im".
Hopefully he will be along soon.
Me personally I'd rip that FI **** off there and install a carb.
Old Aug 5, 2016 | 07:35 PM
Meastly's Avatar
Meastly
Next time it doesn't start I will pull the plugs, it fired right up last time I tried. If I can't get this sorted out I may end up converting to carb.
Old Aug 5, 2016 | 08:40 PM
langwilliams's Avatar
langwilliams
have you tried cycling the key a few times then starting it?
Old Aug 5, 2016 | 08:44 PM
Meastly's Avatar
Meastly
I have cycled it on and off a few times when it doesn't start, but I would try to start it everytime as well. I haven't tried cycling a few times then trying to start it. That is something I will have to try the next time it decides to not start.
Old Aug 5, 2016 | 09:17 PM
98hotrodfatboy's Avatar
98hotrodfatboy
If you think it's a fuel issue you can always open the throttle plate and give it a little shot of fuel then crank it over and see what happens.... At least you can rule on fuel....
Old Aug 6, 2016 | 12:28 AM
Beemervet's Avatar
Beemervet
Oh you carb guys!
Do you have the service manual? Don't do anything until you pull the codes. Let us know what you get.
Old Aug 6, 2016 | 01:00 AM
Zerk's Avatar
Zerk
If the plugs are dry like you say, how can the fuel pump be working? Either that hole in line somewhere.
Dry plugs, no fuel. No fuel no start. Spark has nothing to do with it.
