Need Some Clutch Help
Old Aug 13, 2016 | 12:29 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I'd say operating friction.
Old Aug 13, 2016 | 01:10 PM
grbrown's Avatar
grbrown
Red face
Originally Posted by 0maha
According to the diagrams I'm looking at, the inner race isn't supposed to be welded to the rod. Is that correct?
Does the discolouration on the ends look like factory heat treat, or is that from operating friction?
That black stuff ain't healthy! Your thrust race started out life as two identical thrust washers with the bearing between them, so they should all be nice shiny clean steel.
Old Aug 13, 2016 | 01:11 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I suggest removing the clutch plates/discs and take a look, the spring plate may be kaput...
Item 23 in the illustration:
http://www.stcharlesharleydavidson.c...-80929-H030061
Old Aug 13, 2016 | 02:09 PM
0maha's Avatar
0maha
Getting deeper and deeper.
Got the primary cover off and the clutch out. The push rod does not look healthy at all. All spalled up. I think that was the cause of the clutch mis-behavior. Even getting it out took a couple of hits from a dead blow hammer to break it free. The way I see it, if that rod isn't moving freely, adjusting and operating the clutch (correctly) is not possible.
Got the clutch over at Mark's (the indy next door...everyone needs an indy next door). He's finishing up with another guy's bike, then we're going to pull the clutch apart and see how it looks. He thinks sandblasting the pushrod will get it back in shape. I'm going to take a gun cleaning brush and go through the shaft (that's the transmission mainshaft, right?) that holds the pushrod and get it cleaned up too.
Still hoping to find a definitive root cause to all of this. I honestly don't think my clutch or cable was ever so out of adjust that it would have caused the bearing to grenade like that. I guess anything's possible, but I just don't see it. Maybe we find something in the clutch that explains this, but even then I'm scratching my head. Up until a few days ago when all this started, everything operated perfectly.
Old Aug 13, 2016 | 07:46 PM
Beemervet's Avatar
Beemervet
Oh well. At least nothing else can go wrong!!
I tried to warn you about the voodoo that you do!
Old Aug 13, 2016 | 10:16 PM
0maha's Avatar
0maha
Almost there. The good news is the clutch itself checked out fine.
Got the main pushrod cleaned up. Sand blasted it, then chucked it up in a lathe and sanded it down a bit. Looks new.
The piece that sits right behind the clutch adjust bolt was really bad. It had mushroomed out badly. Got that sorted as well.
New bearing end piece (with umbrella) should be here Tuesday. Hopefully that is the end of this.
For now, I've got the primary side mostly back together. Those big bolts do take some tightening, don't they?
Mark is one of those guys who is a massively disorganised genius. His shop is large (at least 10k sq ft) and absolutely packed with everything. What isn't filled with large, stationary tools is filled with various engine parts lying around, and I swear he knows where each and every piece is at. It's quite the place.
Old Aug 14, 2016 | 05:48 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Don't expect a lot from the push rod. The heat treating for end was probably a thin case harding on the end. That surface went the instant you used it for friction welding. No amount of polishing and machining will put it back. You should be fine for the short term but the clutch adjustment may go away in the long term. All those small part going thru there need replaced including the end adjuster screw if it showed wear.
Old Aug 14, 2016 | 10:04 AM
0maha's Avatar
0maha
That's an interesting point that I hadn't thought of. These parts aren't particularly spendy. There is some wisdom to buying all new bits just for the peace of mind.
Thanks for your help.
Old Aug 15, 2016 | 10:00 AM
0maha's Avatar
0maha
That will make it erratic. Ever things adjusts fine but soon as it's running, it goes to crap. Clutch was not correct and it was spinning all the time. That is what the slack in the cable is for. Of course if the main adjustment is correct FIRST...
Only spins when clutch is pulled in. Be sure to check both ends of your push rod and the faces they run it. That is toast. Never seen one that bad.
Figured something else out.
Here is the diagram that RIPSAW posted:
On my '90, that thing is two pieces: The adjuster screw itself looks like a piece of allthread, and then there is a separate "stub end" to the pushrod about 1.5" long that runs between the adjust screw and the main pushrod.
From what I can gather, the MoCo changed that out in '91 at the same time they added the umbrella. With the new design, the adjust screw is now integrated with the stub end into a single piece.
The adjust screw like mine is obsolete, but I found one on ebay. It looks like this:
I ended up ordering the complete kit from DS. Looks like this:
That's the '91+ design, but the book and the parts diagrams say it should all fit.
Old Aug 16, 2016 | 10:56 AM
corliss@bakerdrivetrain.com's Avatar
Good job on getting all new rods, once they heat up like that they get warped and bent and won't work worth a chit.
That being said the issue you are describing sounds like a shifter pawl needs to be adjusted. If it up shifts okay but does not down shift I would be checking the shifter pawl adjustment.
It needs to be centered in 3rd gear.
Poor clutch disengagement will give you hard shifting up or down.
