I think I would pull the timing chest open and look in there. Look particularly at the inner cam bearing. If that is all OK, then take the rocker boxes off and inspect.
What's inside the oil filter? Cut it open and see.
I would inspect the cam bearing, may be a roller found it's way out. It was suggested by a member here to put a strong magnet on the cam before pulling...this may keep the rollers in the camchest area, you do not want them falling to the crank side, ask me how I know.
Found adjustable push rods had been installed by the previous owner so made it easy to take apart.
Inner cam bearing looks good. Have not measured it but does not seem to be much, if any play in the crankshaft bearing. The cam is in good shape as are all the gear teeth.
Found the rollers on two of the lifter had about .010 of play. But even with that much play I don't see how the piece I found could have passed between the roller and the side of the lifter body (sorry no way to post a picture of the piece).
I had just changed the oil and filter. Upon draining the oil did not see a metal particles in it. Will be taking off the oil filter and mount and flush all the lines. Will cut open the filter and see if there is anything inside.
I am wondering if the metal is a piece of trash left over from when the previous owner had the solid push rods removed and put in the adjustable ones.
