oil filter
Old Sep 18, 2016 | 10:47 AM
HKMark23's Avatar
HKMark23
Originally Posted by 0maha
The problem with all that permanent filter stuff is there's no evidence that any of it means anything.
Back in engineering school, ,,,,,,,,,,,, etc.,,,
Originally Posted by Dr.Hess
That's a good point, Omaha. It is like the "statin" drugs. ,,,,,,,,,, etc. ,,,
As I mentioned, paper filters have been doing the job for a long time.
No-one can argue that paper filters don't do the job. They've been around far too long for that.
Its the paper filter makers who are claiming 5 micron capability, and not delivering, while the permanent filter makers rate theirs typically between 25 and 35 microns. The "point" in addressing this is that with nominal ratings you have absolutely no idea whatsoever what actual filtering capabilities are. A filter rated in "absolute" terms tells you within 85% accuracy or so that it filters out particles larger than its rating.
Too much ? Not enough ? = not the point ! BS vs no BS is the point. You can debate tolerance issues all the way into chaos theory if you wish but I still doubt Engineers spec things out as "X".
Permanent filter buyers chase diminishing returns because, to them, its worth it among other things, to know what they're buying. If it isn't worth it to you , don't buy one but at least now you know what it is you are / aren't buying. Choices are 25-35 microns vs "X".
Thats the point.
Old Sep 18, 2016 | 11:23 AM
0maha's Avatar
0maha
Exactly.
It is the nature of hobbyists/enthusiasts to over-do things.
I'm a guitar player. I have guitar-playing friends who have spent over $10k on custom-made instruments. In reality, from the perspective of someone in the audience, not one person in 100 could tell the difference between their $10k custom job and a properly set up, off-the-rack, $750 Yamaha, but they think it is worth it.
Understand that I am not being critical of your decision. It's your bike and your money. Makes no difference to me what you do with either.
But the question was about oil filters, and it's my opinion that there is no evidence that OEM/equivalent filters are anything other than perfectly suitable.
Old Sep 18, 2016 | 11:58 AM
glidein wide's Avatar
glidein wide
Exactly why I use Drag Specialties oil filters.... holy crap....
Old Sep 18, 2016 | 12:00 PM
HKMark23's Avatar
HKMark23
Exactly.
I hear you bro., however, OEM shocks, cams, tires, breathers, EFI tunes, etc. etc are suitable too. People nonetheless change em, even those who aren't just overzealous neophytes. Its always an exercise in diminishing returns, worth the price to some and not to others. Deciding begins with being aware of the alternatives.
Old Sep 18, 2016 | 12:16 PM
AlanStansbery's Avatar
AlanStansbery
I like the K and P Engineering filters. It was about $150 up front, but I save about $10 every oil change by cleaning it. That's 15 oil changes, at one per 5,000 miles, at 75K miles it's paid for itself in absolute terms or nearly so. You have to replace the o-rings every once in a while. They cost a few bucks. So it's not like you'll save a bunch on such a filter, except over the very long haul maybe.
I didn't buy it for that purpose so much as my belief it's a better filter than the paper filters. Based on the posts in this thread, that remains to be seen I guess. LOL.
If I was going to go with a paper filter, I'd probably do the Harley filter, or K&N which has a nice 'bolt' on the end for removal.
Alan
Old Sep 18, 2016 | 04:40 PM
Owtlaw's Avatar
Owtlaw
We could probably run without a filter and be just dandy on our 3000 mile oil changes, unless you have a messy failure of some kind. Even then, a piece of old window screen would probably catch anything that would cause further damage.
But these are our babies, and we'll happily over-engineer the crap out of everything. Carry on. ;-)
Old Sep 18, 2016 | 06:14 PM
langwilliams's Avatar
langwilliams
I thought I read somewhere not to run the small micron filters or it wasn't necessary to. The evo filter is like 30 microns an the TC is 5 or 10. the large tolerances in the EVO motor makes it not necessary. Don't know if anyone has seen anything like that.
Old Sep 19, 2016 | 12:21 PM
Uncle G.'s Avatar
Uncle G.
Exactly.
Not to hijack the thread, but it's cool to see another guitar player on this site. Yes, guitar players have never had it better in terms of affordable, quality instruments. On the other hand, I'd be embarrassed to say how much I've spent on guitars over the last 49 years. At least I know where my money went.
Old Sep 19, 2016 | 12:26 PM
02Deuces's Avatar
02Deuces
K&N or Drag Specialty filters for me...
Old Sep 19, 2016 | 12:50 PM
RLH3175's Avatar
RLH3175
Back in engineering school, I had a professor who liked to use the phrase "Measure it with a micrometer, mark it with a piece of chalk, cut it with an axe."
What he meant by that is that accuracy and precision are only meaningful if they are actually relevant in a specific engineering context. For example, consider the steel building that THC just built. It's made from a bunch of beams that are bolted together. The straightness of the building depends on the precision with which the holes are drilled into the beams. The engineering question then becomes "How precise is precise enough, and at what point is money spent on additional precision wasted?" No doubt it is theoretically possible to drill the holes in the beam with sub-micron precision. It is also true that anything within something like 1/16" is probably good enough.
In the case of engine oil and oil filters, I've never seen any evidence that filtration beyond that provided by OEM (or equivalent) filters makes any difference in any meaningful way. Sure, you can point to filter "X" and say it "filters better" than OEM, but what evidence do you have that it matters? Is the engine going to run cooler? Is the engine going to produce more power? Is the engine going to last longer? I think the answers to those questions are all speculative.
I don't have any evidence that those filters are going to hurt anything other than your wallet, but I don't understand what problem you think you are solving by using them.
Exactly, I am 69 years old, I have used mostly Fram filters all my life, I buy new vehicles and drive a minimum of 10 years, 200,000 miles, my 2004 Titan pickup has 205,000 on it right now, uses no oil between changes, does not smoke, my 1996 Harley has either K&N or Fram and it has 93,000 miles. No one can talk me into changing to any other filter based on their experience when I have 69 years of my own.
