Brake Review
Old Nov 2, 2016 | 08:02 PM
aces&8s's Avatar
aces&8s
Default Brake Review
I had been noticing my front brake not feeling normal and seem to be dragging or not fully releasing the rotor disc. After scoping it out I decided to just put on a real made in the USA brake before something bad happened at 70 mph. PM, 4 piston, was my first choice.
Easy bolt on installation and nearly no drag on disc. One finger braking with nice modulation. Nice up grade to Evo
Old Nov 2, 2016 | 08:13 PM
Hackd's Avatar
Hackd
pretty!
Old Nov 2, 2016 | 08:15 PM
aces&8s's Avatar
aces&8s
Originally Posted by Hackd
pretty!
Thanks, Kinda classy with function.
Old Nov 2, 2016 | 09:17 PM
Fatboy1389's Avatar
Fatboy1389
wow !!! stops on a dime ? nickel change?
Old Nov 2, 2016 | 09:26 PM
Notgrownup's Avatar
Notgrownup
Good front brakes are nice to have...and when it looks good it makes it all better.
Old Nov 2, 2016 | 10:03 PM
Prot's Avatar
Prot
Glad to hear it. Looks good too.
Is that the same wheel you were having trouble with a couple of months ago?
Old Nov 2, 2016 | 11:34 PM
Yamaharley's Avatar
Yamaharley
Glad you dig it. I swapped my stock single piston for a pm 4 piston caliper after a close call. It was singly the best thing done to the bike to make it a safer ride. If you didn't swap the front springs yet, a new set for your weight will give you less brake dive and a braided line gives some real solid brake feedback. Keep us posted how you like it.
Old Nov 3, 2016 | 06:49 AM
grbrown's Avatar
grbrown
Thumbs up
No change out of some big dollar notes, I suspect!
Old Nov 3, 2016 | 09:04 AM
0maha's Avatar
0maha
Of the various things I've done to the FLHTC, the most significant by far was the new front calipers. Saved my bacon recently, in fact.
Good calipers aren't cheap, but they are way cheaper than feeding tubes.
Old Nov 3, 2016 | 12:21 PM
aces&8s's Avatar
aces&8s
Yes, same front wheel with new tube in it and has been holding air just fine.
