Tsm
Old Dec 29, 2016 | 08:08 PM
Ruggs59's Avatar
Ruggs59
Default Tsm
How the hell does this happen? I was having problems with the left directional working intermittently. Safe to say I need a new one.. Do i have gremlins or mice? Anyone have one they want to part with?
Old Dec 29, 2016 | 09:33 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Wow, that's pretty messed up... No i don't have one. Did you try to clean out all the debris and check the circuit board? Maybe it can be repaired.
Old Dec 30, 2016 | 07:58 AM
Owtlaw's Avatar
Owtlaw
It would sure be worth a shot. Sometimes crud or corrosion can form what amounts to jumpers on a pcb and cause shorts. Merely cleaning a pcb with denatured alcohol can be effective. Repairing damaged traces and pads is also possible, but not easy.
Nothing to lose, anyway
Old Dec 30, 2016 | 08:34 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I would run jumpers instead of trying to repair traces and pads.
Old Dec 30, 2016 | 08:41 AM
Ruggs59's Avatar
Ruggs59
Well that rubber backing looks like it was liquid poured originally. It don't want to peal off.
Someone has been at the TSM in the past because on each end someone wrote 98RK on it.
so it looks like I'll just go get a new one.
Old Dec 30, 2016 | 09:40 AM
RLH3175's Avatar
RLH3175
You can check on Ronnie's at http://partsfinder.onlinemicrofiche.....asp?make=hdmc
or check on Amazon
https://www.amazon.com/Badlands-Prod...+signal+module
Old Dec 30, 2016 | 10:09 AM
texashillcountry
Dirt don't hurt
Looks like the cheapest is Boardtracker at $116
http://www.boardtrackerharleyonline....odule-68540-96
Old Dec 30, 2016 | 10:12 AM
Uncle Larry's Avatar
Uncle Larry
Consider a used unit?
http://www.ebay.com/sch/i.html?_nkw=...&ul_noapp=true
Old Dec 30, 2016 | 11:31 AM
Ruggs59's Avatar
Ruggs59
Originally Posted by RLH3175
The badlands unit is interesting and a lot lees costly. Didn't the OEM cancel off the speedo? And being the BadLand cancels after 11 seconds on it own. Will there be issues with the electronic speedo?
iDodgimus
Apr 28, 2014 11:47 AM
TO34
Apr 14, 2012 02:45 PM
tx-skydiver
Wheels/Tires
Jul 10, 2010 10:59 PM
Thundercloud
Apr 10, 2009 01:10 PM
easy4me
Aug 14, 2008 10:12 AM
