Anyone running tubes in there cast wheels?
Old Jan 1, 2017 | 08:51 AM
TPost's Avatar
TPost
Default Anyone running tubes in there cast wheels?
My rear tire has a very slow leak. About 10lbs over a week or so. I've checked the tire and there are no issues. I was thinking a bad valve stem or possibly rim corrosion at the bead. I talked to my local Indy and he said the early cast wheels had some minor issues with being just porus enough to cause the situation I am experiencing. Has anyone else here had to add a tube to there cast wheel? Thanks, Todd
Old Jan 1, 2017 | 10:21 AM
aces&8s's Avatar
aces&8s
Yep, I had a slow leak in the front and put a tube in. No more leak.
Old Jan 1, 2017 | 04:15 PM
WP50's Avatar
WP50
Yes been done me and a couple others here
WP
Old Jan 1, 2017 | 05:16 PM
grbrown's Avatar
grbrown
I had my 1990 FLHS wheels professionally refinished, which cured that problem for me. The whole wheel was repainted, including the well inside the tyre. Otherwise a tube is fine. Replace your rubber valve stem, which is another possible source of a leak, I even had a valve leak once, a yet further possibility.
Old Jan 2, 2017 | 04:05 PM
RedHogz's Avatar
RedHogz
Put in a tube and don't look back.
Old Jan 2, 2017 | 07:55 PM
Dr.Hess's Avatar
Dr.Hess
I remember one time, years ago, when I was hanging out at the Indy. "Dis Guy," somewhat well-to-do (not scooter trash), brought his bike in for a tire change. The wrench, Gypsy, had his cast wheel on the floor. He didn't have the right tubeless valve stem for the wheel. Without asking, and while the guy looked on in horror, he pulls out his huge electric drill with a way too big bit in it and drills out the cast wheel valve stem hole so the tube stem would fit. "There." The look on the guy's face was just priceless. RIP, Gypsy.
Old Jan 3, 2017 | 01:17 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If someone did that to my wheel I'd break their jaw!!!!!!!!!!!!!
The whole reason I went to cast wheels was to get rid of the tube!!!!
Old Jan 3, 2017 | 10:55 AM
grbrown's Avatar
grbrown
Just occurred to me I have a bike I've owned for umpteen years. It has cast wheels yet recommends tubes and I always have used them. Particularly on early bikes that had cast wheels, using tubes was common. Early tubeless bike tyres weren't very reliable.
Old Jan 3, 2017 | 11:13 AM
Beemervet's Avatar
Beemervet
I always used tubes in my Lester wheels on the BMW boxers. Got pretty darn good at fixing flats by the side of the road.
Old Jan 3, 2017 | 04:50 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Yes, I've heard of cast wheels leaking before. Had it happen on my track car in the early 1980's.
Instead of a tube ( that weighs more, is outa balance & retains heat from the tire carcass) what we did was remove the tire, spray a sealant on the whole rim surface thus sealing the "hole."
When the tire is inflated, the sealant is forced into the hole/crack/crevass thus sealing the air pathway.
