99 Electra glide radio
Old Jan 17, 2017 | 08:35 PM
Clint13's Avatar
Clint13
5th Gear
Exclamation 99 Electra glide radio
My farther has a 99 Electra glide that he hadn't rode for 2 yrs so the battery was shot. The radio worked fine when he parked it. After installing the new battery when you turn the ignition on the radio starts humming. When you hit the power button on the radio to turn it on it just makes another humming sound with a different tone. No clue what it's doing. Easy fix for now pulled the radio fuse. LOL has anyone had this happen? Any help would be greatly appreciated.
Old Jan 18, 2017 | 06:11 AM
flhchaz's Avatar
flhchaz
You may want to try to put this in the audio section of HD Forums.
Old Jan 18, 2017 | 07:47 AM
grbrown's Avatar
grbrown
Wink
Start by checking and cleaning power and ground wires to the radio and speakers. Electrical problems are often actually mechanical, meaning that they are caused by something like dirty/broken/corroded connections. Disconnect every connector, clean and refit using dialectric grease, to provide a protected connection.
Old Jan 18, 2017 | 10:46 AM
14GuineaPig's Avatar
14GuineaPig
Any chance that the mice got to it while it was parked for 2 years?
Old Jan 27, 2017 | 09:41 PM
Clint13's Avatar
Clint13
5th Gear
No mice. Everything wire wise is good
Old Jan 27, 2017 | 09:55 PM
Beemervet's Avatar
Beemervet
If you need to replace it, let me know. I have one.
Old Jan 27, 2017 | 10:04 PM
Clint13's Avatar
Clint13
5th Gear
Ok thanks
Old Jan 29, 2017 | 10:09 PM
brad75raiders's Avatar
brad75raiders
Fuses are under the Left leg side panel I had a few bad fuses retro radio wouldn't work but biketronics walked me through it
Jomondre Frink
Audio Systems
Apr 15, 2017 06:55 PM
woodglide07
Audio Systems
Aug 27, 2012 05:32 AM
wessels
May 1, 2009 08:39 AM
01ElectraGlide
11
Nov 2, 2006 09:46 PM
jpetty
Feb 16, 2006 10:27 AM
