Other than questioning the EIM is the (2) wires connected to the coil. 98hotrodfatboy mentions swapping. I assume there are just power supply to the coil so don't understand why that would make a difference. At same time I can't trace these (2) wire back to a source on the wiring diagram.
As a two wire it wouldn't... If three then it would be a single fire and would make a difference. Your cam position sensor is the correct one... 32448-95a matches with the EIM of 32449-95a good for carbed.... I would lean toward your EIM being bad..
The timing cup behind the sensor is different for an efi and carbed bike.
-OP where did you get that part number? Just make sure that it is for a carbed bike. It does matter.
