Spark plug color and tank trim
Old May 14, 2017 | 12:48 PM
R.N.CUMMINS's Avatar
R.N.CUMMINS
Default Spark plug color and tank trim
Thought I had my super tuned rather nice, but it was on the factory plugs the bike came with in 85. I put new plugs in and I've twice now had to lower the idle and retune the mixture. Thinking maybe I have a issue, as plugs now look lean. Bike doesn't start as nice, has to roll a few times before it fires ( did fix my no starter issue on previous thread). Right plug is rear jug, which also has a little black around head gasket. Just brainstorming.
Tried to buy chrome tank bib, couldn't find one for a 85 fxsb, tried the 77-84 fxs/sb bib from drag, big no go. If someone needs it, cost of shipping it's yours. If someone can point me to a chrome one that fits that would be great.
Old May 14, 2017 | 12:49 PM
R.N.CUMMINS
Old May 15, 2017 | 07:00 PM
Hey Man's Avatar
Hey Man
Yup definitely lean. If the only thing you did was change the plugs then the heat range of the new plugs is probably too hot because the speckling on the rear plug is most likely from over heating. Stop riding it until you fix the problem. You may want to check for intake leaks also. If the seals are originals from '85 it's a good bet they need changing. Please let us know the outcome.
Old May 15, 2017 | 07:14 PM
Yankee Dog's Avatar
Yankee Dog
How many miles are on those plugs?
Old May 16, 2017 | 10:14 AM
R.N.CUMMINS
Intake seals are new as I pulled the butterfly carb setup off and put new Super e stuff on. Doesn't mean this thing didn't rattle them loose though lol. In this picture plugs had maybe ten miles, put another 45 on and they look the same just more black on the base.
Old May 20, 2017 | 05:14 AM
glidein wide's Avatar
glidein wide
Did you check J&P cycle for the bib?
Old May 20, 2017 | 05:18 AM
Yankee Dog's Avatar
Yankee Dog
I think you need more miles on those plugs to determine if too lean. Any pinging or spark knock? I am not seeing any gross signs of lean/overheating. Just no color except at base ring. 10 miles won't tell much. YD
Old May 22, 2017 | 07:55 AM
Hey Man's Avatar
Hey Man
What jets are in the Super E? Is your air mixture screw set right? Whenever I see plugs like that I think too lean, too hot or both. Especially that speckled one and the fact that it came from the rear jug.
Old May 22, 2017 | 09:13 AM
Yankee Dog's Avatar
Yankee Dog
I'm not seeing any specks. I am seeing the early formation of a timing indicator ring on that right plug. But again I don't see any specks on the porcelain. Take a look at the diagram/link below. Lots of good info on reading a spark plug.
Can get more info than many realize. YD
http://i577.photobucket.com/albums/s...eadingJPEG.jpg
Old May 22, 2017 | 11:07 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Have to agree, right plug is showing a little too much advance and don't forget to much timing is like changing the AFR. I would check that and go from there...
You want the timing band to be in or just below the bend in the ground strap....
sk1sk1
Jul 14, 2017 11:18 AM
Bluesrider.df
Engine Mechanical Topics
18
Apr 4, 2016 02:35 PM
Jessie
May 10, 2008 12:02 PM
matinees
Sep 16, 2007 03:35 PM
PMZ XL 1200
Apr 19, 2007 08:58 AM
