Taking my EVO on the road
Check the ground wire to the frame from the neutral switch. I swapped 'em out and no luck. Then found the ground wire broken off where it mounts to the frame. Works very well now.
I had blinker issues like yours. Work/not work. Swapped out handlebar controls for newer ones. Same issue. Swapped out the TSM and works like a charm. Try that.
As to the trip.. I did 4200 miles two up, pulling a cargo trailer on my non-stock 94 ultra a few years back in 18 days and didn't even add any oil to it. I use it for my road trips as it is setup the way I want it for cruising. Larger motor, six speed, etc.
I am also a AAA Premier RV member which gives you 200 miles of free towing if needed.
Griz
I recently replaced the stator (at about 50,000 miles) How long do they usually last? Is that something to consider replacing every so often as a preventative measure?
Griz
Where exactly is the neutral switch. I have been looking for it and cannot find it.
I have checked the ground to the frame under the seat and it appears fine to me on a visual inspection. Is there a way to check it electronically?
If you look under your oil tank you will see a brown wire with a cup like fitting on it.
That wire is connected to your neutral switch.
Since you stated the bike spend some time exposed to the elements: Your neutral light issue might be a bad connection at the top of the transmission. Blinkers: I'd check the bulb sockets for corrosion. Clean with a bit of fine emery cloth. Dielectric grease is your friend. I need to go over all the bulbs/sockets on my bike and clean/grease.
I have never looked at the wiring diagram for a FLSTC, but I have seriously studied the ones for the FLHS, FLHTC, FLHTCU, FLTC, and FLTCU. The full blown E-Glides have a lot of circuits/wiring. The FLHS is far simpler. I would imagine in complexity, your FLSTC compares to my FLHS, in circuits/wiring. Helpful Hint: Take the FSM wiring diagram down to FedEx Office and use one of their enlarging copiers. Blow that puppy up to a 'user friendly' size. Make multiple copies. You can then use colored markers to track circuits. Keep one copy unmolested so you can make additional ones if needed. I did this when I was figuring out how to HackFab install a Harley electronic cruise control kit (for a FLHTC) unto my FLHS.
That being said, unless your looking at a charred tangle of wires, I'd first just look at the connectors for corrosion. Clean (you can get aerosol electronics cleaner) them. Use some steel wool wrapped around a pipe cleaner or a Q-tip if necessary. Some of the terminals can be brightened up a bit with emery cloth.
Good luck, and start a thread if you run into problems. Post pictures!!!
Oh, and I've done a bit of wiring:
