Taking my EVO on the road
Old Jun 4, 2017 | 04:10 PM
  #61
Sorg67's Avatar
Sorg67
I don't think the Versys is fundamentally more reliable than the FLSTC. It is just a 2013 with 9,000 miles on it compared to a 1992 with 50,000 miles on it.
Old Jun 4, 2017 | 04:26 PM
  #62
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
My '94 has about 67k miles and my '95 has 145k approx miles.
I'd have no problem hopping on either (although the '95 would be more comfortable) and heading to Alaska if that was in the plans.
It's not the miles it's how well you took care of your vehicle (and I don't mean cleaning!!!)
Old Jun 4, 2017 | 09:01 PM
  #63
Sorg67's Avatar
Sorg67
This is the problem. I have only owned if for a year and I have caught up on a lot of neglected maintenance. I think it is pretty solid now except for the electrical system. I think florida heat and humidity, living part of its life outside and part in a small trailer have caused some corrosion.
I have replaced a few wires, the stator and the turn signal control module. The neutral light does not work and the turn signals work fine in the garage, but they work inconsistently on the road.
I worry that I could be stranded by an electrical problem at any time. I would like to replace the entire wiring system, but my mechanic advises me that doing so could open a can of worms and is at a minimum, very tedious.
I have been advised that my symptoms sound like a ground issues so I am planning to see if that solves any of my problems.
But at the moment, I feel like the Versys has a higher probability of getting me there and back without any problems.
Old Jun 5, 2017 | 06:33 AM
  #64
Hackd's Avatar
Hackd
Either bike, enjoy the ride!
Old Jun 5, 2017 | 08:53 AM
  #65
texashillcountry
Dirt don't hurt
As I mentioned before I have replaced the main wiring harness on both of my bikes and yes it is tedious but well worth it IMO.
Old Jun 5, 2017 | 12:09 PM
  #66
Sorg67's Avatar
Sorg67
You are probably right. Perhaps a lot of effort, but a learning experience, peace of mind and perhaps save me from getting stranded some day.
Old Jun 5, 2017 | 09:07 PM
  #67
KevinMT's Avatar
KevinMT
Pull the bulbs out of the blinkers use hand signals jump on that bike and ride. If it breaks down call a friend with a pickup. It's only 600 miles, make an adventure out of it. Odds are it will make it just fine.
Old Jun 5, 2017 | 09:29 PM
  #68
Sorg67's Avatar
Sorg67
I do think I would enjoy the trip more on the Harley. And I have only been stranded once so far when the stator died. And I have fixed a lot since then. So I probably would make it and it would not be the end of the world if I didn't. Might give my son and adventure to come rescue me.
Old Jun 5, 2017 | 11:30 PM
  #69
Amos Iron Wolf's Avatar
Amos Iron Wolf
If don't have one consider the manual push button for the starter solenoid. My bike goes in tomorrow for the 10K and a solid going over. It sat a bit before I got it. The fellow kept it serviced and took good care of it, but sitting and time have let the contacts in the right side controls get a little corroded.
The right turn button has been a little wonky now and then. A few times now I would have strong lights, push the starter button and nothing. Not a thing. First time it happened I had just gotten the bike inspected then it wouldn't start. I called my friend and he came over. Just when I was about going to get some contact cleaner and dielectric grease and take the controls apart he says "Wait, I know a magic trick."
He then leans over, reaches under the seat area and BAROOM the bike fires right up. It had been so long since he had used it he had forgotten that he had a button installed on the starter. After that the handle bar switch worked fine except a few times lately I have had to reach down and press the button. Works everytime.
I haven't messed with anything because the bike was already scheduled to go in for a good front to rear and all points in between. Since the cables will be getting lubed and checked and I will be having them install Kuryakyn ISO grips at the same time that issue will be addressed too.
That little button can mean the difference and a lot of comfort when you have good lights and no matter how much you push that bar mounted button nothing, not even a click happens.
I just managed to do around 200 miles with the wife yesterday as our longest yet on this bike. However, that button is a real nice piece of comfort. And it's been the difference a few times between start and no start.
Old Jun 6, 2017 | 10:11 AM
  #70
texashillcountry
Dirt don't hurt
Sounds like you need to read the adding a relay sticky.
