Clutch cable issues
Old Jun 12, 2017 | 05:49 PM
Richard Winquest's Avatar
Richard Winquest
Stage I
Default Clutch cable issues
I just installed 15" ape hangers on my 1997 FLHT and after installing the clutch cable ( 8" extended length ) I cannot get the cable adjustment to tighten up as there is a considerable amount of adjustment to get the clutch adjusted. I have also tried to install a EZ clutch spacer on the cable thinking that would take up enough slack but no luck. There is no excess cable and I'm thinking that the cable is not right. Any feedback would be appreciated.
Old Jun 12, 2017 | 06:03 PM
0maha's Avatar
0maha
Back off the clutch adjust a bunch. Push in on the cable to ensure that the ramp inside the trans is properly oriented. Then adjust the clutch. Then adjust the cable.
Old Jun 12, 2017 | 06:09 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Last time I had a problem like yours it turned out that I had reassembled the bottom attachment (the 3 ball bearings) in the wrong position.
You might double check that.
Old Jun 12, 2017 | 09:29 PM
rizzo's Avatar
rizzo
Check the release bearing while you have it apart.
Old Jun 15, 2017 | 06:45 PM
tbear640's Avatar
tbear640
Smile Clutch Cable Issues
Thanks to all who replied, it turned out to be the ramp mechanism that was not oriented correctly so the problem was corrected and my son is out riding right now. I'm trying to get him interested in this forum as it not only contains a mountain of great info but also a way for him to get to see what others out there are doing and riding with their bikes.
klkordzi
EVO
May 28, 2019 05:53 PM
AAAC
EVO
Apr 16, 2014 12:03 AM
Tucker99
EVO
Jul 26, 2013 02:44 PM
machm1969
May 7, 2013 05:00 PM
skos
Oct 23, 2008 03:46 PM
