replacing cam soon
Old Jul 3, 2017 | 05:37 PM
dports70's Avatar
dports70
Default replacing cam soon
im planing this winters project so i can save the funds, i have a 92 flhtcu, with 43k im planing on putting a cam ( E13 or E27 ) not sure which one.air cleaner, and reject.
thinking while im in might as well replace the lifters & push rods and lifters.
http://www.ebay.com/itm/Adjustable-P...3D121956535493
this is 1st harley so im kind of looking for recommendation that should be done around this milage..
Old Jul 3, 2017 | 09:01 PM
Anthony Paul's Avatar
Anthony Paul
Save yourself the head ache and stick with S&S valve train. Those after market parts are not a good choice for durability and longevity. I've had those cheap ones fail before, long ways from home I was 2 states out on I-75 when one of my lifters let loose. Cost more to get the bike back home (plus engine damage) had I spent the money on a good vale train. Just food for thought... Good luck!!
Old Jul 3, 2017 | 09:29 PM
dports70's Avatar
dports70
that's why I'm here asking, learnt a lot over the last year from this forum
Old Jul 3, 2017 | 11:13 PM
langwilliams's Avatar
langwilliams
I've heard good things about these:
http://www.ebay.com/itm/Lifter-Set-U...BVr6lp&vxp=mtr
with you mileage I'd replace them and the cam bearing to be safe. cam is a personal choice pick one with a power band that matches your riding style. I liked the ev-3010 I had in my Fatboy.
Old Jul 3, 2017 | 11:39 PM
dports70's Avatar
dports70
i aasumes replacing the cam cam bearing was something that's was automatically done when the cam is replaced, I mean you're right there might as well.
i ride an electra glide them seem to be the 2 recommended cams, I just cruise, ride mostly with the wife most, not looking to build a race bike, just want the power when needed to go up them hills or around the slow moving vehicles if needed
Old Jul 4, 2017 | 04:36 AM
rockhousebadboy's Avatar
rockhousebadboy
I did a top end rebuild on my 97 FLHTCUI a few winters and 18k miles ago. Installed the EV 13 and love it. Have nothing to compare it to other than the stock cam but really improved the bike. Also used the Hylift- Johnson lifters mention above with no issues. Be on the lookout for a cam bearing removal and installation tool if you don't already have one. You can probably find one on ebay or the forum classified. I couldn't find one when I needed it and ended up buying one and then selling on classifieds. I was out $20 but well worth it to have the right tool in my opinion. Good luck.
Old Jul 4, 2017 | 06:02 AM
Durham man's Avatar
Durham man
He might get lucky with cam bearing , my 92 Fxr was manufactured in 7-91 and had the Torrington , early 92 still had the torringtons
Old Jul 4, 2017 | 07:59 AM
glidein wide's Avatar
glidein wide
Free tool rentals at auto parts store,blind hole puller will swap the cam bearing in less than five minutes. That's what I used.
Old Jul 4, 2017 | 12:46 PM
Uncle G.'s Avatar
Uncle G.
Even so, I'd still put in a new bearing with a cam change. Even the "good" bearing may not last forever, and you're already right there. Why wouldn't you?
Old Jul 4, 2017 | 12:53 PM
Durham man's Avatar
Durham man
My bike had 28 k on it and the bearing looked and felt fine , I guess if mileage was higher I would have, also kept my stock lifters in there for now , I did do the steel breather,
