Engine light came on today.
Old Jul 9, 2017 | 02:24 AM
WindowMan's Avatar
WindowMan
Default Engine light came on today.
I had my red engine light come on today so when I got home o read on how to read the codes. If I ran the sequence correctly I got an error code 14.
What is this code for?
Thanks Michael.
Old Jul 9, 2017 | 06:28 AM
rockhousebadboy's Avatar
rockhousebadboy
52,53,54,55 bad news ECM replacement
56 crank/cam sensor ---very very common, any backfire gives this one.
11 throttle sensor
12 barometric 14 engine temp. sensor 15 intake temp sensor
23 and 32 are injectors front/rear
24 coil
33 fuel pump relay
Old Jul 9, 2017 | 02:40 PM
WindowMan's Avatar
WindowMan
Just my luck the Vacaville dealer does not have an engine temp sensor in stock.
Old Jul 10, 2017 | 06:35 AM
rockhousebadboy
not to many dealer are going to stock that part. Was only used on first 4 years of fi bikes.
Old Jul 10, 2017 | 11:30 AM
WindowMan's Avatar
WindowMan
I found one at the Sacramento dealer and he is holding it for me.
Old Jul 11, 2017 | 05:54 AM
carlgrover's Avatar
carlgrover
code 14 is the engine temp sensor. P/N is 32446-95A (I think, that's from memory). You can buy them online from Ronnie's HD for about $80. If you spend another $20, you get free shipping.
I keep a spare in my shop. When the old one goes bad, I replace it then order another one for the next time. I'm averaging about 20k until they go bad and need replacing.
It's an easy fix. You don't need to pull the tank. Just remove the tank bolts, push the tank forward then slip the fuel crossover tube over the coils and pull the tank back. Prop it up out of your way with an old shoe, block of wood, rags, whathaveyou and replace the sensor.
carl
Old Jul 11, 2017 | 08:52 AM
WindowMan's Avatar
WindowMan
Carl yes that is the part number, I ran up to the Sacramento dealer and picked the only one they had and then ran up to Nevada City and picked up a set of rineharts slip ons since I got them cheap.
Old Jul 11, 2017 | 08:57 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Thanks Michael.
How hot was it that day and was the bike idling for a prolonged period? Cause that'll do it when the is no real problem. Reset the ECM and ride it a while and see if it comes back.....
Old Jul 11, 2017 | 09:52 AM
WindowMan's Avatar
WindowMan
It was pretty hot here later in the day 101 but the light came on during my morning commute when it was only 80. Guess I could reset it and see.
Old Jul 11, 2017 | 11:59 AM
WindowMan's Avatar
WindowMan
I don't remember seeing one that had emc on it but wasn't looking, any idea which one it might be?
