Slow turn over
Old Jul 17, 2017 | 05:21 AM
grbrown's Avatar
grbrown
It's not your engine's fault, so leave the ignition alone! Do the usual checks, such as the connections at both ends of both main power cables, to make sure they are all clean and tight. Also check the ground strap under the trans, which should also be clean and tight at both ends. In other words make sure your starter is getting as much power as possible, before replacing anything.
Old Jul 17, 2017 | 05:28 PM
glidein wide's Avatar
glidein wide
Well all righty then.....I just figured if my starter armature was starting to develop a short,then it would draw more and turn slower...can't say I knew how low the voltage drops while turning over.
It's hard wired for my smart charger and if I plug it in,it's over 80% for about 15/20 minutes then at full charge. So I was thinking that's not too bad really,my tractor batteries take way longer to reach full charge.
Old Jul 17, 2017 | 07:05 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
In your case the only thing that matters is that your battery failed the load test.
It did that when the voltage dropped to 7.5 when you hit the start button.
I don't know if that is your only problem but you won't be able to reliably diagnose anything else until you replace that battery with a good one.
sB43
EVO
25
Aug 12, 2018 07:20 AM
11deluxeguy
May 2, 2018 10:52 AM
Aussie rider
EVO
Apr 29, 2018 06:34 AM
ssbogger77
Electrical/Lighting/Alarm
Jun 3, 2017 08:56 PM
Jeff47
May 2, 2017 08:21 AM
