Intake Gaskets
Old Jul 18, 2017 | 06:11 AM
flhchaz's Avatar
flhchaz
Default Intake Gaskets
Another job on my ever growing list to replace the intake gaskets. Are the stockers from the motor company good enough replacements? What is everybody using?
Old Jul 18, 2017 | 06:28 AM
misfitJason's Avatar
misfitJason
I think they are. Really your only two other options are the thicker blue ones. Or if you really want to get fancy you can get the fueling ones
Old Jul 18, 2017 | 07:25 AM
Uncle G.'s Avatar
Uncle G.
The stock gaskets have worked for me for the last 15 years.
Old Jul 18, 2017 | 07:51 AM
WP50's Avatar
WP50
The last 3 sets I have used were stockers
WP
Old Jul 18, 2017 | 08:49 AM
Ruggs59's Avatar
Ruggs59
The stockers are your best choice
Old Jul 18, 2017 | 09:12 AM
flhchaz's Avatar
flhchaz
Thanks. Stockers it is.
Old Jul 18, 2017 | 11:45 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I've had my motor apart so many times in the last 3 years that I didn't even give them a chance to fail.... Used what comes with the Cometic kit...
Will say this though the, the best breather valve is the OEM green ones.... They last a long time. Twice as thick as all the rest....
Old Jul 18, 2017 | 01:50 PM
0maha's Avatar
0maha
WP
How often do you change them out!?!?
I did the ones on mine at about 25k miles, just because CVP included a set with the carb rebuild kit. AFAIK, the ones I replaced were the originals, and they were probably just fine, but far be it from me to leave something alone!!
Old Jul 18, 2017 | 03:17 PM
flhchaz's Avatar
flhchaz
The reason that I am changing them is I had an Indy replace a head gasket a couple of years ago. The valvetrain has been noisy ever since. I took the tappet screen out to check it and it was filled with sludge.
I'm thinking he was sanding bodywork next to my bike with the motor opened up and the dust got inside. I have changed the oil a couple times and it is good now, the oil stays clean and the tappet screen stays clean also.
I've got about 60k on her and figure is be best to swap out the lifters and one of the adjustable push rods has a stripped spot in it. While I'm in there with I'm going back to stock push rods with my EV 27.
I am going to replace the intake manifold gaskets while its all apart, for piece of mind.
Old Jul 18, 2017 | 03:48 PM
rockhousebadboy's Avatar
rockhousebadboy
If your bike is FI and its never been changed, spring for a new Air Intake Temp sensor while you're at it. You have to pull the manifold to change that sensor if it ever goes out. It's about $25 and will take you all of 60 seconds to change while the manifold is off.
