Speedo cable
Old Aug 5, 2017 | 12:49 AM
Beemervet's Avatar
Beemervet
Default Speedo cable
Oh, the joy of having an EVO with a mechanical speedo. On a run the speedo started acting strange then quit. Today I pulled it out along with the cable. Everything looked OK until I looked closely at the point where the cable enters the speedo and saw a piece of the inner inside. I tried for an hour to get it out to no avail. I reinstalled the original speedo that has a dead odometer but the speed works. These things are hard to find so I'm looking for someone who may have a tip for extracting the broken tip.
Old Aug 5, 2017 | 05:57 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If you could post a picture of what you are dealing with that might help.
Old Aug 5, 2017 | 06:36 AM
1340hog's Avatar
1340hog
I had a 98 ultra that did the same thing.Mine broke at the wheel so it was a little easier to get out.I used a two small flat head screw drivers with a dab of grease on them and slowly worked it out,P.I.T.A. My biggest problem was matching a new one,dealer could not find the right one.Spent an hour looking in all there books.Ended up ordering one thru drag specialties.First time i ever saw or heard of a dealer ordering thru an after market supplier.
Old Aug 5, 2017 | 06:49 AM
RANGER73's Avatar
RANGER73
You could try drilling it out. You know, with one of those micro bits in your drill kit that you never use. I think the speedo end is plastic.
Old Aug 5, 2017 | 07:12 AM
1340hog's Avatar
1340hog
Mine was aluminum and the only thing holding it in was grease
Old Aug 5, 2017 | 06:57 PM
WP50's Avatar
WP50
I have gotten a couple out by blowing air from a compressor beside the sleeve that the cable goes into.
Some old sticky grease can cause them to seem stuck more than they really are.
WP
83flh-bigboy
General Topics/Tech Tips
May 30, 2012 02:15 PM
fogcity123
EVO
Jun 5, 2010 12:36 PM
Blown 331
EVO
May 23, 2008 10:46 AM
janne63
EVO
Oct 3, 2007 01:23 PM
Scott39
Jun 16, 2007 10:40 AM
