Spell Casted
Old Aug 14, 2017 | 08:04 AM
grbrown's Avatar
grbrown
Thumbs up
String came first! Yes, that's all I use, along with the Mark 1 eye.
Old Aug 14, 2017 | 09:18 AM
Schex's Avatar
Schex
You have to adjust the rear wheel 90* vertical to the frame first,
well actually, adjust rear wheel axle parallel to the pivot shaft is first.
Front rotor 90*, same as rear, doesn't matter where the handlebars point or if stuff is bent, then you can string it.
Just stringing it will get you crabbing down the road too, if that's good enough for ya.
Hey Bumbandrun, I see where your username came from,
I raced Karts 11 years
Old Aug 14, 2017 | 10:59 AM
grbrown's Avatar
grbrown
Talking
And I just thought he was good at dodgems!
Old Aug 14, 2017 | 05:39 PM
1997bagger's Avatar
1997bagger
Originally Posted by Bumpandrun
Not being a wise azz as I do have lasers I have used in kart racing and oval track cars. But does anybody just string there bike after sitting it level? I understand the vibration bs won't use anything but soft sloppy HD rubber now on my everyday bike . The good stuff is too damn stiff. Use it on the hot rod stuff.
Started doing the string thing, just way too much room for for human error plus my once calibrated laser eye can't see to the other end of the string
Old Aug 24, 2017 | 08:28 PM
1997bagger's Avatar
1997bagger
Loading up the AR and possibly Twinkie hunting, can't get rid of the 1600-1800 vibration, I mean bounce your sunglasses vibration. Followed alot of advice here, did fix the 2000 rpm vibration under accel. Checked the compensator and tightness, clutch nut, loosened the exhaust, Glide Pro front mount, put a PowerCommander on it to alter fuel in the problem area, new plugs, SEA FOAM didn't even fix it, put the bike on a lift and checked for engine clearance, exhaust clearance.
Haven't never ran this engine above 3500 rpms and problem showed up all at once as mentioned earlier. Ran it up into higher rpms and can feel engine vibrations matching engine speed in the floor boards, 1600-1800 is a paint mixer until the clutch is pulled. Thinking bad news, adjusted the primary chain tighter when checking inside the primary, road it to work 35 miles and the vibrations below 2300 rpm became unbearing and waiting for parts to fly off, smooths out 2500-3000 on the interstate but then can start feeling it in the floorboards when going higher. The tightening of the primary chain making the vibration go off the charts, I think I have a scissored crank, checking run out on the pinion side most likely prove it and in a way will be sad and happy
Old Aug 24, 2017 | 08:37 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If I remember right WP50 had something like that and it turned out to be a clutch hub problem. As in too much play in the clutch hub or something like that.
Old Aug 24, 2017 | 08:58 PM
1997bagger's Avatar
1997bagger
My ears are open, I checked the clutch hub tightness, pulled the center plate off and hit it with a impact, reverse threads
Old Aug 24, 2017 | 09:29 PM
texashillcountry
Dirt don't hurt
You'd have to get with WP for the exact details but as I recall with the clutch hub mounted he was able to shake it back and forth either an eighth of a quarter of an inch.
Sorry I don't remember more.
Old Aug 24, 2017 | 09:50 PM
0maha's Avatar
0maha
I remember him talking about that last year at the meetup. IIRC, he ended up replacing the whole thing.
Old Aug 25, 2017 | 07:39 AM
WP50's Avatar
WP50
I gotta get to work I'll ck back here this evening.
WP
