'86 FXST Front End Custom Build Questions...
Does anyone here have any experience with swapping out the front forks of an old FXST ('86) to a springer front end? And, possibly willing to walk me thru what pieces and parts I'll need besides the front end? I've got a few leads on front ends but I'd like to not build a death trap and work myself into a bad rake/trail scenario. So any input is greatly appreciated.
I'd really like to run a fatter front tire as well because I like fat tires like I like chubby chicks. And, I learned that means I'm looking for an FL or Heritage Springer front end. Are there years that are better than others? Also, I'd like to run spoke wheels but all the info has me a hair confused.
I know this isn't a fast process and in fact I'm a pretty patient guy these days. But I am a planner, researcher, and like to learn the proper way to do things. I've already been ran over by a negligent cager and lost my left leg below the knee so I'd like to not build a bike that's a death trap. I'm building it to ride not show so being within safe parameters for handling is important to me.
After messaging with Tom84FXST a couple times he appears to sound like a reliable source for info, but I also wanted to get info from others as well. Any tips, hints, or points toward solid resources is greatly appreciated.
Have a good evening fellas!
P.S. I cross posted this from the Softail forum because they have tons of info on newer models, but lack info for my 31 year old FXST.
I have ridden a few springers and will say this. Buy an oem springer or a paughco. One with a shock works better. Don't buy a DNA
If you get a complete front end off of an evo springer softail it will probably just bolt up. But you didn't tell us anything about the frame you have to know about rake and trail and length needed. Most custom frames and stock frames use a one inch stem.
RamblnRose84 (08-17-2017)
Thanks for taking the time to respond.
Also, it appears I'm on the right track. Because after looking around the only front ends I am considering are OEM or Paughco.
A stock softail frame has 30 degree rake to the neck. The softail standard and custom have raked trees. The fatboy and heritage do not. That being said the springer will not either. But the springer is an entirely different front end but can use the same neck cups.
An oem springer will bolt right up to your bike. A stock length paughco springer will bolt right up to your bike, You will need different wheel spacers, front brake caliper, fender, and handlebar risers to go from a regular telescoping hydraulic front end to a springer.
here you go. This is a catalog from paughco for their springers. They are very good quality.....but pricey. I have had a few over the years. Oem holds up well too. The reason why I say NO to DNA is that they buckle and break. Very cheap build quality. That being said there are a ton of other companies that make custom springers with different looks and prices. I would plan on spending over a grand to do it. Keep posting here if you have any other questions and take a gander on ebay for used takeoff. You best and cheapest route is going to be to buy an oem takeoff used on ebay or a local shop hopefully with the wheel, brake, and caliper.
http://www.paughco.com/2008-catalog/index.html
Springers are de-raked in the stem...The FX 4.5 degrees ...the FL 7.5 degrees...you can buy a kit from vulcan to remove the de-rake so they are an inline springer...you have to do the math on trail to see what that will do to the handling.
http://vulcanworks.net/store/Harley-...-Rake-Kit.html
Is it the 4.5 degrees Tom84FXST mentioned below?
Johnny-5
06-04-2011 04:42 PM
