Replace clutch plates and spring??
Old Feb 8, 2018 | 09:43 AM
marktruckee's Avatar
marktruckee
Default Replace clutch plates and spring??
Rebuilt my 1990 FXRS with 10.5 pistons & .0040 over, S&S 520 cam, and had heads ported/polished with valve job. Plan on using existing Python I staggered exhaust with Mikuni 42MM. (may upgrade exhaust and go with bigger Mikuni down the road).
I'm putting together primary now and took apart clutch pack for inspection. All parts look great. Metal plates show no sign of blueing; with no warpage. Friction plates exceed factory specs of .661, with no scarring, and have appear to have plenty of meat left. Stock spring appears to show no signs of wear.
I'm inclined to put the stock pieces back together and run it 'as is.'
Given my upgraded engine, does anyone have opinions if this is a bad idea?
Or is it best be prudent and replace all with a 15%+ spring?
Attached Thumbnails Replace clutch plates and spring??-img_1260.jpg   Replace clutch plates and spring??-img_1205.jpg
Old Feb 8, 2018 | 11:38 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I ran some pretty Stout Evo's, low 90's hp/tq, 3k-6500rpm and never had an issue with stock setup...
Old Feb 8, 2018 | 03:52 PM
aces&8s's Avatar
aces&8s
not a fan of the spring plate. Seen the damage they can do. Extra plate works better
Old Feb 8, 2018 | 04:44 PM
flhchaz's Avatar
flhchaz
I would also get rid of the spring plate. When they come apart, the brass rivets make a mess of everything.
Old Feb 8, 2018 | 06:59 PM
aces&8s's Avatar
aces&8s
At 30k mi my clutch was giving me problems shifting, spring plate ate up the clutch hub. Hub cost about 3 bills. Extra plate shifted better and hooked up much better. No brainer to drop in the extra plate.
Old Feb 9, 2018 | 10:19 AM
marktruckee
Ok, given the condition of existing steel/friction plates, can I just buy two more steel plates and one more friction plate? Or do I need to buy a whole kit, to replace all steel/friction plates?
Old Feb 9, 2018 | 10:25 AM
1997bagger's Avatar
1997bagger
Ya, it happened to me, those rivots will come apart and can barely get it to go in gear.
Had good luck with a Energy One clutch kit behind 100 hp, Barnett and several others make a good clutch kit
https://www.energyoneclutches.com/home.php?cat=15
Old Feb 9, 2018 | 11:41 AM
grbrown's Avatar
grbrown
I ran my Glide with a S&S 107" engine and stock plates for quite a while, just used a stronger spring. I have since swapped to a set of +1 kevlar plates from Barnett.
Old Feb 9, 2018 | 01:09 PM
aces&8s's Avatar
aces&8s
Yep "Energy one" and "Barnett", had both and both are great.
Old Feb 9, 2018 | 03:51 PM
flhchaz's Avatar
flhchaz
I used the HD kit that eliminates the spring plate, its the same one used in police models and 110 inch bikes. Tough clutch pull and reduced friction zone though. I may try one of the Barnett clutch cables.
