Front end oscillation.
Old Jun 23, 2007 | 04:32 PM
co80120's Avatar
co80120
Stage IV
Default Front end oscillation.
Maybe someone can help with this. I've got a'96 Heritage Special. Front forks were bottoming out and the handlebars would ocillate back and forth thru a wide speed range. Had the local HD shop rebuilt the forks and put in heavier fork oil. No more bottoming out but there is a slight ocillation between 37 and 40 mph only, otherwise the bike travels straight with my hands momentarily off the handlebars. (you know, adjusting the helmet or rolling up the [/align]sleeves.)Any thoughts. ta[/align]
Old Jun 23, 2007 | 08:20 PM
blackonly's Avatar
blackonly
Default RE: Front end oscillation.
I had this on a fatboy and all i did was put a new front tire on. Took care of it..The tire that I took off only had 5k on it..
Old Jun 24, 2007 | 09:20 AM
co80120's Avatar
co80120
Stage IV
Thank you for the input. I just couldnt figure it out. The front tire does have 15K on it and looks like it is in good condition. It will be do for a change here in the next 5k when I change out the rear. Thanks again
Old Jun 24, 2007 | 01:16 PM
Mokey's Avatar
Mokey
put it on a jack and check the fall away. The neck bearings may need to be tightened
Old Jun 24, 2007 | 04:14 PM
co80120's Avatar
co80120
Stage IV
Thanks Mike. I've got a co worker who works on bikes. I may just take it over there and have him check it out. Thanks again. ta
Bubbarules1958
EVO
29
Apr 15, 2017 08:31 AM
Sliver1
Jan 1, 2014 11:47 AM
ralix13
Dec 8, 2011 07:00 PM
toaster
Feb 14, 2010 11:23 AM
rickoshay45
Mar 23, 2008 11:19 PM
