Oil for Dyna
Old May 15, 2018 | 07:26 AM
TDH Rider's Avatar
TDH Rider
1st Gear
Default Oil for Dyna
What oil is to be used on a 1998 Dyna Super Glide Convertible FXDS?
Old May 15, 2018 | 07:34 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Which oil???
There are 4 different oils used on that bike, Motor, tranny, primary and forks.
You will find that just about everyone has a different opinion on what to use.
Personally I use Valvoline VR1 20w-50 in the motor, Amsoil 75-140 in the tranny, Atf in the primary, and Amsoil hydroshock in the forks.
ps Welcome to the forum
Old May 15, 2018 | 07:48 AM
Yamaharley's Avatar
Yamaharley
I agree with td. Except because your in canada it probably wont be texas hot up there, hence i would go 75w-90 in the trans. If your not a fan of auto trans fluid in the primary use a good 10w-40 made for bikes with wet clutches. Good luck and welcome.
Old May 15, 2018 | 01:38 PM
Daedalus's Avatar
Daedalus
Hah, an oil thread
I use 20w50 full synthetic in everything but the forks and brakes.
Old May 15, 2018 | 04:22 PM
Beemervet's Avatar
Beemervet
Old May 15, 2018 | 05:10 PM
TDH Rider's Avatar
TDH Rider
1st Gear
Default Proper oil to use
thanks everyone. Just waiting for the manual. Takes about 5 weeks to get one
Old May 15, 2018 | 05:28 PM
Beemervet's Avatar
Beemervet
You should be able to get one from ebay or Amazon quicker than that!
Old May 15, 2018 | 08:47 PM
Uncle G.'s Avatar
Uncle G.
I’ve used HD 20w-50 in the engine for the last 216,000 miles. It seems to work okay. HD “Formula +” in the primary and Valvoline 85w-140 Gear oil in the transmission.
Old May 15, 2018 | 09:14 PM
Erik Lundberg's Avatar
Erik Lundberg
This is what I use in my Fat Bob 2013 but there are many other brands.
Red Line 20W60 Motorcycle Oil in engine
https://www.redlineoil.com/20w60-motorcycle-oil
V-Twin Transmission Oil with ShockProof
https://www.redlineoil.com/v-twin-transmission-oil-with-shockproof
V-Twin Primary Case Oil
https://www.redlineoil.com/v-twin-primary-case-oil
Old May 18, 2018 | 06:23 AM
Hackd's Avatar
Hackd
Use the same, with the exception I recently switched the trans oil to Royal Purple. It's a lot easier to read (old man/old eyes) the level on the dipstick since it's 'purple'.
