Ignition question
Old May 29, 2018 | 05:32 PM
mdazb's Avatar
mdazb
Default Ignition question
Was given a Crane Hi 4 ignition system from a friend. Are these any good?
Old May 29, 2018 | 06:05 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by mdazb
May be a dumb question but here goes.
Can you run a single fire coil with a stock cam sensor and a SE race module? Will it run?
As long as the module you are putting in is able to work with a single fire coil you will be fine.
There are several modules out there that will run either single or dual fire depending on where you set the switch.
Old May 29, 2018 | 06:20 PM
mdazb's Avatar
mdazb
Thoughts on the HI 4 unit?
Old May 29, 2018 | 06:23 PM
55 Pan's Avatar
55 Pan
they are good units..I personally don't use them... just an FYI if you are unsure..use a 3 ohm coil.
Old May 29, 2018 | 06:39 PM
bentparts's Avatar
bentparts
Been using the Crane Hi4 as a single fire with Crane's coil for many years, good unit, very reliable and multi adjustable.
Old May 29, 2018 | 08:18 PM
texashillcountry
Dirt don't hurt
Personally I think you would do better to get a Dynatek 2000p or a Daytona Twin Tec. JMO
Old May 30, 2018 | 06:00 AM
carlgrover's Avatar
carlgrover
I've got a Crane Hi-4 in my ironhead. No problems. I like it.
carl
Old May 30, 2018 | 11:07 AM
KozmoSoftail98's Avatar
KozmoSoftail98
I love mine. If you are replacing the stock ignition it is way better. You got it for free, install it and see what you think. It can be adjusted very easily to suit your timing needs.
Old May 30, 2018 | 12:17 PM
mdazb's Avatar
mdazb
Yeah I did get it for free with coil. Need to find a install manual and schematic online and go for it.
Mrukus
EVO
Jul 2, 2013 09:50 PM
jimjam31
EVO
15
Jan 26, 2012 08:43 PM
KingPinVinny
May 4, 2010 02:36 PM
87XLH1100
Sep 22, 2009 02:20 PM
hddee
Shovelhead
Apr 23, 2008 09:09 PM
