How do you Static time a evo motor? i removed the pickup and forgot to mark it. i know get the TDC mark in the window. can i put a volt meter on the coil or something and turn the pickup till i get a reading or something?
set piston in front cylinder at TDC on compression stroke
center vertical line in timing hole
turn ignition on
make sure run switch is on
using volt meter, measure voltage between GN/W wire from sensor plate and ground while rotating sensor plate
to do that, follow wires from sensor plate to ignition module connector
back-probe the GN/W wire at connector
(it may be GN wire instead of GN/W on your bike)
when voltage changes from 0 V to 4-5 V (or vice versa), stop, set sensor plate
