A stock Evo with 8.5 compression should run just fine on regular unleaded. If it doesn't you might want to fatten up the mixture.
My Evo gets nothing but 87 including the EPA mandated 10% ethanol blend.
A freind told me he has been running 87 with an octane booster.. Seems like it might work well and you may even come out cheaper in the long run. The main thing that concerns me with 93 is that no one is using it these days (at least not many folks). This leads to the fuel sitting for longer periods and possible contamination... Just a thought.. I curently run 93, but will likely try the booster idea..
Dumping booster in there is gonna cost more than buying premium. As far as sitting in the tank - how long you reckon that gas sits in a ship while it making its way here from Saudi Arabia?
I sometimes run the premium, but usually run 89 octane. I can run 87 in cooler winter weather, but in Texas it might be a high of 30F today, and 85F tomorrow. Easy enough to try the different octanes, and then use the one that suits your bike and your riding style best.
