Stripped torx
Old Jul 6, 2018 | 10:26 AM
Dr.Hess's Avatar
Dr.Hess
And if you use a left handed drill bit, chances are that it will grab at some point and back the thing right out.
Old Jul 6, 2018 | 11:30 AM
WP50's Avatar
WP50
I have counted on that happening a good many times and it has. Thankfully
WP
Old Jul 7, 2018 | 05:51 PM
megawatt's Avatar
megawatt
I remove and discard Torx fasteners on my vehicles replacing them with hex socket cap or standard hex cap fasteners.
For me, the Torx fasteners and their bits fail (strip out or break apart) often.
They seem to work okay for deck screws (like building a wood deck) but sadly that won't help you with your problem.
Cutting a slot in the head and using some heat (if possible) does work well.
I have had to weld a piece onto bolt heads that I can get a adjustable end wrench on for the worst ones.
Use penetrating oil too.
The very best penetrating oil I have used is Cabots Tasgon.
Not sure if it is still available. Where I worked they stopped using it because if you get it in your eye(s) it causes immediate irreversible eye damage.
I finally bought some reverse flute drill bits but have not had occasion to use them yet.
But I'm sure I will some day...
Old Jul 8, 2018 | 04:21 AM
grbrown's Avatar
grbrown
I've learned the hard way that cheap Torx tools are crap. I now have Snap-on (or whatever their cheaper brand is) and haven't had any problems since.
Old Jul 8, 2018 | 07:08 PM
barneyboy's Avatar
barneyboy
I couldn't agree more, and for the most part, all cheap tools are crap.
For those that are considering replacing their torx fasteners with conventional fasteners, here's some interesting information (Scroll down, and click on Principles of operation).
https://en.m.wikipedia.org/wiki/Torx
Old Jul 8, 2018 | 07:40 PM
Beemervet's Avatar
Beemervet
Wiki info is only as good as the contributor provides. I treat torx fasteners like megawatt does........ I shitcan them. No regrets, and no issues.
Old Jul 8, 2018 | 07:51 PM
barneyboy's Avatar
barneyboy
The contributor is a mechanical engineer. Good enough for me.
Old Jul 8, 2018 | 07:58 PM
Dr.Hess's Avatar
Dr.Hess
Whenever I want to know what an absolute idiot knows about a subject, I go straight to wikipedia.
Old Jul 8, 2018 | 08:08 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Hey Shem did you ever get the bolt out??
Old Jul 9, 2018 | 09:04 PM
langwilliams's Avatar
langwilliams
My three boys are mechanical engineers an I can't get them to check their own oil!
