Oil light on when engine hot
Old Sep 10, 2018 | 11:39 PM
uwiik's Avatar
uwiik
Default Oil light on when engine hot
My engine oil light is on when the engine is hot. Tried to check oil level by the tank while the engine is hot and running and oil sprayed from the oil tank inspection plug. What would be the problem? Worn oil pump or just plugged passage or something else?
Old Sep 11, 2018 | 03:50 AM
Kingglide549's Avatar
Kingglide549
Indonesia?
howdy.
Is this a new thing?
Next is a real gauge to verify your idiot switch is not being an idiot -maybe that should be the first thing you should do?
I would.
If I remember the EVO is supposed to have 8 to 10 lbs at idle @ the correct idle RPM, which is very important.
of course, there is the chance there is the wrong oil in the bike. 20-50 is about right.
Old Sep 11, 2018 | 03:55 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Are you talking idle? There is a pressure retainer ball or plunger to maintain idle pressure for the light. Usually, it is oiling and when that seat area gets worn or trash in it, it sets the light at idle and other then that, it's OK. Depending on year, there is about 5 different valves. Usually in and around oil filter or in the exit line at oil pump. Add a signature line on your bike similar to mine..
Old Sep 11, 2018 | 08:52 AM
uwiik's Avatar
uwiik
Originally Posted by Kingglide549
Indonesia?
howdy.
I would.
Yeah, from this other side of the world, all good bud 👍
Not new to this, been in many on and off relationship with evo since 1999 but always with non stock or incomplete bike without any functioning dash this is the first time I have stock evo bike and also this problem, not the idiot light but the oil tank pressure build up. I know now that idiot light is not to be trusted and I need to get proper gauge 😁 but what worried me the most was the pressure release from the oil tank. I tried to inspect the oil level and return flow, purposely left the engine on while undoing the oil filler plug like I sometimes do with my 2012 Fatboy, to my surprise I was immediately sprayed by damn hot oil from the opening. It wasn't very pleasant at all I can tell you 😫... I don't think pressure supposed to buid up inside my oil tank.
Old Sep 11, 2018 | 08:56 AM
uwiik's Avatar
uwiik
Yes, when I either idle or gliding through without throttle. As soon as I give it a gas it dissapear but I have pressure build up inside my oil tank.
Old Sep 11, 2018 | 09:12 AM
Tom84FXST's Avatar
Tom84FXST
Sounds like a vent problem.
Could be overfilled with oil,,,,could be a kink in the vent hose...
You didn't say what year the bike was...makes a difference on the vent system.
Old Sep 11, 2018 | 07:08 PM
uwiik's Avatar
uwiik
It's a 1998 Fatboy, top venting.
Luckyeight
General Topics/Tech Tips
Nov 13, 2018 10:58 AM
amc_76
Panhead
Jun 25, 2014 12:03 AM
96_nostaligia
Mar 4, 2014 04:24 PM
grantuk
EVO
20
Sep 28, 2010 08:59 PM
Harley Bass
Ironhead
Jul 3, 2008 09:30 PM
