i just rode a thousand miles and most were at around 70-80 mph. In the last half, my speedo needle wouldn’t hold still and was “dancing” for lack of a better word. It jumped around +\- 3mph.
Whenever I’d stop for a break and turn the bike off, and then back on again, it’d work as it should but that would be in a town where I’d be going slow. Once I’d speed up, the needle would hold steady but only for a minute or two then start bouncing around.
You need to take a look at the speedometer. If it has a cable screwed into the underside of it, it’s cable driven. If it doesn’t, it’s electronic.
If you don’t know how to get to the underside of it, you probably should spend the money for a service manual which will also tell you which type of speedo it is.
Cable. It's probably on the way out. You might be able to lube it and get some more life out of it. I'm on about my 7th or 8th cable. I'd have to check my logs.
