Rocker Arm Assembly
Old Oct 31, 2018 | 11:24 AM
daven9113's Avatar
daven9113
Default Rocker Arm Assembly
If I have the older rocker arm assembly (non-breather), and I would like to run with breather heads, do I just need to get the middle rocker cover? I think the lower cover and upper covers are the same, but not sure.. Thanks.
Old Oct 31, 2018 | 01:18 PM
Kingglide549's Avatar
Kingglide549
I think you need a whole bunch of other stuff to run breather heads.
The timing cone is different afaik TOO.
Why would you want to switch?
In this case the bottom breather is better than the top in my opinion.
Old Oct 31, 2018 | 02:05 PM
daven9113's Avatar
daven9113
I'm thinking about putting an Evo motor together. Right now, I would be putting a '97 flywheel assembly in a '88 case, and I have '97 heads, but non-breather rocker cover assembly laying around.
My plan was to get '93 later cone cover, and build a top breather engine, and just wanted to know if I needed a different set of rocker cover assembly, or just the different middle rocker cover section, since it's the one that has the umbrella valve.
I think the upper rocker cover and lower cover rocker are the same, but needed some input. Thanks.
PS. I also prefer lower case breather too (my 89 FL). No data to compare the two, except bro-science. Less potential mess and maintenance to deal with, but I think they both work well.
Old Oct 31, 2018 | 02:15 PM
Kingglide549
AFAIK it is not just the cone cover, the inside of the case is slightly different for a head breather.
Compare the gaskets.
Call someone that really knows Scott at -Hillside perhaps?
PINKSTF9
EVO
Apr 17, 2018 04:39 PM
kyfatboy1972
Mar 22, 2012 04:12 PM
pturner
Jul 6, 2010 01:13 AM
Big Arnie
Mar 17, 2008 06:20 AM
bhendricks
Jan 11, 2006 11:30 PM
