Model/Year differences
Old Feb 3, 2019 | 08:29 AM
splattttttt's Avatar
splattttttt
just checked this on line because I know that 98 and 99 was a pivital year between the evo and twinks
But the fatboy wasn’t involved in parts being swapped out for what I assume was a testing phase during that period
In fact, non of the softail line up had yet to be molested by the MoCo in 99. Just the tour line up.
The year the softail frame change occured was in 2000 to house the new twincam motor
So torque specs should be the same for 98 and 99
Great read here -> https://haynes.com/en-us/tips-tutori...tory-1999-2012
Old Feb 3, 2019 | 08:50 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by Gregatron
I was just looking for air cleaners online and the Arlen Ness basic kits aren't as expensive as I thought. So I might do that. Or I'll try to track down a stock one.
And yes, Pieous. So good.
You can probably pick one up at Buds 512-472-8658.
They're out on 812 near the race track.
I haven't tried pizza from there as I heard it was kinda pricey and I'm cheap when it comes to food.
Now for other things that will help that bike if it doesn't already have it are
1) non vacuum operated petcock
Pingel or Golan are probably the best but not cheap.
2) Dynatek (i or p), or Twin Tec ignition module.
Either of those will make cold starts way easier
3) I've found these
Amazon Amazon
very helpful for removing the tanks without having to drain them
You'll have to reroute your crossover line to the outside of the down tubes but it makes life much easier after you get it into place!!!
I get the best prices on aftermarket parts at Antler Creek Cycle Leather 512-441-2427
You did get a front fender with the bike didn't you????
Old Feb 3, 2019 | 11:58 PM
Gregatron's Avatar
Gregatron
Spattt... that's a great bit of info. Thanks for looking it up.
​​​​texashillcountry, I know I'm in for redoing the ignition. The dash switch has to be "wiggled" into operation. So that's getting replaced. Cold starts are rough also because the choke cable is shot and you have to hold it the whole time it warms up. I haven't even considered the petcock yet. What does replacing it gain you?
And yes, I got the matching front fender. Also the guy says that there's the original tank and fenders that they removed for the blue set. I'm hoping to get a hold of those too.
Old Feb 4, 2019 | 03:09 AM
K. Lindberg's Avatar
K. Lindberg
I took my ignition switch apart and cleaned it.
I also had to wiggle it to find the exact position to have ”ignition position”.
Cleaned it and put some grease made for electrical contacts on it, and it worked as a charm after that.
Old Feb 4, 2019 | 05:37 AM
grbrown's Avatar
grbrown
Wink
Take a close look at your choke cable as it has a friction device on it, just behind the ****, and you may simply have to adjust it so you no longer have to hold it open. Most of us have been there!
Old Feb 4, 2019 | 07:01 AM
texashillcountry
Dirt don't hurt
As for the cold starts if you install a Dynatek 2000p then all you have to do is pull the choke hit the start button then let the choke back in and set the throttle lock to hold rpms up til the bike warms up.
As for the petcock if you replace it with one of my recommendations it gives you a better fuel flow, easier operation, and a simpler design with fewer possible points of failure.
Old Feb 4, 2019 | 11:18 PM
Gregatron's Avatar
Gregatron
Ok.
I pulled and cleaned the dash switch. So far that seems to have improved it so... sweet!
I took a closer look at the choke cable and the plastic threaded fittings is what is broken. So it can't hold tension. I might try some epoxy or super glue... but I'm pretty much resigned to replacing it.
I looked up the ignition module and it's now on the list. Not immediate. But it's something I want to do. The petcock I will likely put on the back burner for now unless it starts to give me problems.
I know it sounds like a lot of problems but I will likely get it on the road by the weekend. Hopefully.
Old Feb 5, 2019 | 04:05 AM
grbrown's Avatar
grbrown
Thumbs up
That's the right thing to do. The plastic is not the sort that will readily take to a glue of any sort IMHO.
Old Feb 5, 2019 | 05:45 AM
texashillcountry
Dirt don't hurt
Ok.
Good job on the ignition switch as those damn things are like $100 from the dealer!
As for the choke cable IIRC they are cheap and that plastic nut is commonly what breaks.
When you replace it just finger tight will work don't put a wrench on it.
Old Feb 5, 2019 | 01:31 PM
Gregatron's Avatar
Gregatron
Absolutely. Not everything needs loctite and a torque wrench.
Roukouz
Jun 15, 2015 02:05 AM
dh2683
Feb 1, 2010 03:42 PM
motox26
Apr 25, 2009 09:32 AM
93 fatboy
Mar 3, 2006 03:51 PM
ken05
Nov 28, 2005 03:20 PM
