sealed bearing conversion
However, I understand that people would rather not deal with the mess of properly cleaning and repacking the bearings.
I'm wondering if one of the bearing companies did a custom run of them for someone but they were so expensive that they were never made again.
As for the bearings, have you ever had one go out? If you have, you can understand why I do them every year. I had my front bearings go out on me while on an Interstate, and when they go, they go fast at that speed. by time I pulled over to the shoulder, they were completely seized up. Not fun at all. I don't wait untill my tire is ready for changing, the bearings get greased every year. I have no problem with the mess.......I've done tons of wrenching on my bike over the years. Cams...heads.....exhaust systems......belts....clutches....primary bearings....trans seals.....it's all messy. I got no problems with messy....I do have a problem with taking off that front & rear tire just to pack my bearings when a sealed bearing would save me a couple hours wrenching that I could be spending drinking, chasing skirts, lighting up my farts., or picking my nose.
I have had 2 Harleys with sealed wheel bearings. Never had to pack them, they never gave me any problems. I like that. If you like repackable bearings, why wait untill your tire needs changing? As for your argument about how do you know if a sealed wheel bearing is going bad because you cant see it during routine maintenance, how do you know that your bearings are ok right now at this instant? You don't. They might be about to seize up, you really have no idea. They may have looked good last time you changed your tire, but did you repack them correctly? Do you know that too much grease is bad? How do you know how much gease you are putting in the bearing? If you are not going to look at them untill the next tire change it might be too late. So your same argument can be also used against repackable bearings.
FYI...Torrington reccommends that you pack your bearings 1/3 to 1/2 full of lubricant. Read for yourself....page 19.
http://www.applied.com/apps/commerce/pdf.do?id=61
