1990 FLHS Ignition System Replacement
Old Mar 5, 2019 | 07:49 AM
fshaw's Avatar
fshaw
Default 1990 FLHS Ignition System Replacement
Probably going to replace the ignition system in my stock 1990 FLHS. Looking for a simple, reliable and reasonably priced replacement system that will replace the entire stock ignition system including coils. Looked at some of the options, looking for personal experiences and satisfaction with your choice. Leaning toward dual fire for simplicity.
Thanks.
Frank
Old Mar 5, 2019 | 07:53 AM
JayStronghawk's Avatar
JayStronghawk
One Word , Dynatek
http://www.dynaonline.com/
Racepres's Avatar
Racepres
I really like the Stock system...and the ability to put different "modules" into it.
Look how long it has lasted!!!!!
Spend more to Get more maybe.
Old Mar 5, 2019 | 09:06 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by JayStronghawk
One Word , Dynatek
Old Mar 5, 2019 | 10:12 AM
fshaw's Avatar
fshaw
For you Dynatek guys do you recommend the Model S, 2000, or 2000i
Thanks.
Frank
Old Mar 5, 2019 | 03:14 PM
Mountainkowboy's Avatar
Mountainkowboy
My 89 had a Dynatek 2000.....work like a champ.
Old Mar 5, 2019 | 04:38 PM
texashillcountry
Dirt don't hurt
Thanks.
Frank
As I replied to the PM you sent it depends on wither or not you are keeping your stock cam sensor.
Old Mar 13, 2019 | 08:46 PM
flhsport's Avatar
flhsport
I had my indy install a Daytona Twin-Tec single fire ignition and high output coil with a EV-27 camshaft on my 1989 FLHS and it really helped my S/S Super B carb smooth out and added a lot of response and torque. It did change the sound of the potato/potato/potato at idle but other than that I am really pleased. Just my personal experience.
Old Mar 14, 2019 | 03:18 AM
JayStronghawk
Daytona Twin Tec is also a good option .. I just found the Dynatec a bit simpler to set up ..
Old Mar 14, 2019 | 03:58 AM
Hoginedgewood's Avatar
Hoginedgewood
I have several Ultima ignitions, coil is the weak point if you get a Chinese one. Static timing is a breeze. Lots of flexibility.
emwolb
EVO
Jan 30, 2011 11:07 AM
Candubrain
Dec 14, 2010 07:43 PM
harleymark
Mar 4, 2009 08:32 PM
crissguinn
Jan 3, 2009 02:22 PM
harleyflo
Jan 11, 2008 10:35 AM
