I have a 1988 FLHTC. I installed a Ultima ignition system over the winter. I've had it out a few times and it ran great. The other day I fired it up got a couple blocks away and it died, like I hit the kill switch. After some cranking it fired up again and I almost made it back home before it died again. Pushed it home and in the garage.
I pulled the fuel line off the carb and made sure I was getting fuel. Thinking maybe something was clogged. It's getting fuel.
I pulled a spark plug and wasnt getting any spark. I checked to make sure that all of the connections were good from the ignition install and couldn't find anything wrong. I pulled the cover on the ignition and hit the start button. It cranks and the lights on the ignition flash like they should. So my thought was the coil went bad.
Tonight out of curiosity I went out pulled a plug and was getting spark. Put it back in the bike and she fired right up. What could have been the problem?
I just did a S&S ignition, does the Ultima replace the coil and eliminate the old ECM?
Did you set the timing correctly? Are your crimp connections solid?
The Ultima replaces the coil and eliminates ECM. Pretty sure the timing is correct. Could possibly be a crimp connection. I did crimp and then heat shrink them.
Apparently, when you were first trying to diagnose, the engine was still warm from riding and you got no spark. Once everything had time to cool down, your spark returned.
Electrical components can fail when hot only to work again when cooled.
Get it warm again and see if it fails again.
I'll try that. Would letting it sit and idol for awhile work or do I need to ride it? A little leery about riding it anywhere. It's a PIA to push.
I've had ATVs and mowers that would do that. Coils broke down after getting warm/hot. That's the first place I'd go.
