Passing lights from Hell
Old May 3, 2019 | 07:58 PM
Rustyg500's Avatar
Rustyg500
Originally Posted by sB43
I'll put a new one in just to make sure.Should I just put in a 15 amp, or maybe bump up? Kinda makes sense about a weak breaker. (They're J&P) maybe go get some original HD?
Never a good choice. The purpose of a circuit breaker is to protect the wiring it is protecting. If you install a breaker with more capacity you risk the possibility of burning up your wiring. Replace with like amperage or, as a test, simply swap the offending CB with another one on the bike.
Sounds like you have a short somewhere. Lights go off, the CB has popped. Lights come back on the CB has reset itself. Get yourself an OHM meter and start looking for grounded wiring.
Old May 3, 2019 | 08:00 PM
Uncle G.'s Avatar
Uncle G.
Why do you need spots for inspection? Headlight, Brake and directionals I would think. Not saying to not fix it but simply why needed for an inspection?
In NY, you don’t need them, but if they’re on the bike they have to work or you don’t pass inspection.
Old May 3, 2019 | 08:02 PM
golfblues's Avatar
golfblues
If you have any connectors in the line I would separate them, check them out for corrosion, assemble with some Dielectric grease and plug them back in.
Old May 3, 2019 | 08:09 PM
golfblues's Avatar
golfblues
When I lived in New York up to three years ago they just checked your headlight, tail, brake and blinkers. And if you look it up it for NY it states they cannot fail an inspection if the fog lights are not working. Driving lights, fogs, same group.
From NYS inspection site;
These items cannot cause you to reject a vehicle. The items are
  • bumpers
  • fog lights
  • Lots more but not needed
Just for info in NY
Old May 4, 2019 | 02:43 AM
Kenney's Avatar
Kenney
Look here: Why you need a Load Equalizer for LED's. (on older bikes)
https://www.customled.com/blogs/cust...on-motorcycles
KenK
Old May 4, 2019 | 06:08 AM
RANGER73's Avatar
RANGER73
KenK
Only applies to signal lights and bikes with CAN BUS.
Old May 4, 2019 | 06:43 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Thought I had some bad ones, bought new (Hogworkz LED). They come on, they go off.
Are you telling us you have had two sets of passing lamps with the same issue?
Where are your passing lamps getting power from?
Old May 4, 2019 | 10:39 AM
splattttttt's Avatar
splattttttt
I had a rear blinker that Satan him self installed a bug to it just to drive me nuts!
Mine would actually alert my ecm that I had an engine problem (2014 softail) and would actually cause all kind of evil issues with how it ran. From afr to drive train woes.
turned out to be the switch in my hand controls
Old May 4, 2019 | 01:20 PM
sB43's Avatar
sB43
Okay, installed new circuit breaker, and doused all connections with dielectric grease. No go. Waiting on my buddy to bring his "high tech tester". Either a bad ground or the switch. Anyone got an old spot switch for an 87 FLHTC laying around? Ordered one from Pinwall a while back, and they sent me a Cruise switch.
Old May 4, 2019 | 02:00 PM
splattttttt
Try cleaning it out. New ones are sealed. Older are not.
