Passing lights from Hell
Old May 4, 2019 | 02:24 PM
WP50's Avatar
WP50
Originally Posted by texashillcountry
Have you tried running a new hot wire to the switch so that the passing lamps only come on when the switch is thrown?
Do this so the wiring to the spots is hot only when ign switch is on.
Might add a inline fuse according to where on the bike you get the power from.
WP
Old May 4, 2019 | 05:20 PM
sB43's Avatar
sB43
not yet, will get back on it tomorrow.
Old May 5, 2019 | 05:31 AM
sB43's Avatar
sB43
from the harness
Old May 5, 2019 | 06:08 AM
Rogue1's Avatar
Rogue1
Originally Posted by golfblues
When I lived in New York up to three years ago they just checked your headlight, tail, brake and blinkers. And if you look it up it for NY it states they cannot fail an inspection if the fog lights are not working. Driving lights, fogs, same group.
From NYS inspection site;
These items cannot cause you to reject a vehicle. The items are
  • bumpers
  • fog lights
  • Lots more but not needed
Just for info in NY
I was a New York State Motorcycle inspector for years. The law states ALL lights that are on the bike at the time of inspection must work.
Old May 5, 2019 | 09:54 AM
WP50's Avatar
WP50
Originally Posted by sB43
from the harness
Was BSing with the TCH. He reminded me that you probably have circuit breakers. Choose one of the 15 amp breakers that are only on when Ing. switch is on.
Older breakers have a stud and nut to attach wires to. Run a wire from harness side of breaker to the switch for the spots (passing lamps) .
Most times when spots are added to a bike the power for them is a wire spliced on to the Headlight low beam wire near the headlamp itself.
WP
Old May 11, 2019 | 05:29 AM
sB43's Avatar
sB43
Sorry it took so long, it's been a busy week. We did find the problem(s). Pinched hot wire, and a so-so ground. Rewired both, and now we're up and running.
Old Sport
Jun 17, 2018 07:24 AM
Macky1986
Nov 11, 2011 09:34 PM
Calwoodbutcher
EVO
Sep 22, 2010 01:31 AM
bladeguy
Jul 13, 2009 03:56 PM
Puggy
Apr 17, 2008 01:03 PM
