Ground wire question
Old May 11, 2019 | 11:38 AM
klkordzi's Avatar
klkordzi
Default Ground wire question
I am changing the handlebars on my 92 Heritage Softail and when I removed the riser bolt on the right side, what I believe is a ground wire that was connected to the riser bolt twisted off. Can anyone tell me what this went to so I can splice it back together? I can't see or feel a broken wire.
Old May 11, 2019 | 12:10 PM
yellowstone kelly's Avatar
yellowstone kelly
Not sure if your '92 is the same as my '96 Heritage, but from the parts diagram for my '96, it sounds like you're referring to #23---"Cable, ground".
I just checked my bike, I don't have that cable/wire installed like it shows here, so I can't tell you where it goes or what it connects to.
Everything on my bike works fine, so I'm not sure if you even need it.
Old May 11, 2019 | 12:25 PM
klkordzi's Avatar
klkordzi
Thanks for the drawing. In doing some searching on the forum, the wire runs from the riser bolt to the triple tree and it's intent is to ground the handlebars since the rubber bushings isolate the bars from the frame.
Old May 11, 2019 | 12:30 PM
TwiZted Biker's Avatar
TwiZted Biker
You need it, without it vibration will cause intermittent contact leading to all kinda goofy electrical issues that will act like something serious elsewhere on the bike, seen guys chase their tails for weeks and spend money swapping parts that didn't need it.
OP the wire usually pulls off at the ringlet under the nut you can't see most times, it frequently get twisted off when people pull the riser bolts.
Old May 11, 2019 | 12:53 PM
RANGER73's Avatar
RANGER73
Under the tank is a 4 post male ground connection point. If you can see the end that broke just extend it. Otherwise pull the right side tank.
Old May 11, 2019 | 12:56 PM
RANGER73's Avatar
RANGER73
The pre 96's use the metal for ground after 96 Harley started to use a real wire for ground because the metal is not reliable
Old May 11, 2019 | 05:33 PM
yellowstone kelly
You need it, without it vibration will cause intermittent contact leading to all kinda goofy electrical issues that will act like something serious elsewhere....
Maybe other bikes are different, but I don't think anything on my bike depends on the handlebars being grounded.
All I have on my handlebars are the left and right turn signals, the run/stop switch, the start button switch, the bright/dim switch for my headlight, the front brake switch, and the horn button.
Per the wiring diagram, no wires from any of them connect directly to the handlebars for a ground. They all go to Deutsch connectors.
Since the Moco has a ground wire in the parts diagram, I'm probably missing something obvious.
Old May 11, 2019 | 07:11 PM
RANGER73's Avatar
RANGER73
His bike is a 92. Did you read post 6?
Old May 12, 2019 | 12:15 AM
yellowstone kelly
I did read post 6.
But I'm still wondering what electrical circuit on the handlebars of a '92 bike (or any other bike) depend on the handlebars being electrically grounded to the rest of the bike.
I'm always looking to learn more about these bikes.
Old May 12, 2019 | 08:56 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I know that my 98 Fatboy needs it for the grounding of my turn signals that are attached to the bottom portion of the mirror mounts...
