Stupid oil dipstick question
Old May 13, 2019 | 03:12 PM
LQQK_OUT's Avatar
LQQK_OUT
Originally Posted by Windseeker
Do you happen to know if that's for Hot or Cold?
Oil level should be checked only when engine is at normal operating temperature. The engine will require a longer warm up period in colder weather. The motorcycle should be ridden to ensure oil is hot and is at normal operating pressure. When the above conditions are met, turn the engine off.
Softails should be upright and level when checking oil.
For Softtails only add oil to bottom of dipstick plug.
Old May 13, 2019 | 03:25 PM
Windseeker's Avatar
Windseeker
I did the oil change with the bike on a T-chock, so it was level at the time. I put in around 2.5 quarts, give or take a bit.
As an aside, I have two oil filter wrenches but they're both for a car or truck so they were a bit too big to grab the Harley filter. I had to run to a local dealer to buy the little filter end cap wrench, which worked perfectly.
I put the filter in hand-tight only, of course, about half filled with new oil and the rubber ring fully lubed.
Old May 13, 2019 | 05:08 PM
RANGER73's Avatar
RANGER73
After the bike has been ridden, with the bike standing straight up check the level hot
It should not be higher than the bottom of the fill neck.
Then after it's cooled, standing straight up, check it again.
A 1/2" to and inch is low is best to avoid oil blowing out the air cleaner..
Old May 20, 2019 | 09:51 AM
richard567's Avatar
richard567
i simply did my oil change, marking the dipstick at 3 qts and then at full...so much easier
NBADER1979
EVO
Feb 14, 2018 12:57 PM
Scudda
EVO
23
May 20, 2012 10:38 AM
shizzomynizzo
Ironhead
Jul 14, 2010 12:12 PM
FL DEUCE
Apr 25, 2008 07:05 PM
magar888
May 21, 2007 11:21 AM
