Changing out the switch housings.
Old May 13, 2019 | 03:48 PM
TexNorth's Avatar
TexNorth
Default Changing out the switch housings.
Hey all, ok, so my 1992 FLHTCU has the controls for the radio and cruise on the handle bars. However, I know the cruise and radio buttons are trashed and I think the other switches are giving me some issues as they are so old and I know the bike spent some time outside. I pulled the radio and don't care that the cruise doesn't work (there are a bunch of things taken off this bike by the previous owner). Anyway, I am thinking of putting on new handle bar switch housings that are just the regular switches, start, run, turn, horn, beam. Do y'all have a suggestion on a "year" range, model ...etc. that I look for in the catalogs to do this? The front brakes seem to work fine so if I can avoid having to replace that, that would be awesome.
I will change the switches as well of course.
Old May 13, 2019 | 06:28 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If you're gonna change switch housings and switches then I'd go with the '96 and newer switches as you can still get housings and switches for those easily.
Old May 14, 2019 | 09:04 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If you go with the `96 and later switches and housings, you will also need to change the master cylinder and clutch handle assembly.
Old May 14, 2019 | 09:17 AM
TexNorth's Avatar
TexNorth
That's what I was wondering, it may have to wait a bit. This may end up being a next winter project.
Old May 14, 2019 | 09:19 AM
Architect's Avatar
Architect
Not sure for your year, but I was able to buy all new switches with the wiring attached for my '97 when I did a handle bar change. That might be the easiest solution, all new wires already soldered to new switches. keep it stock and maybe everything will still work when done. Kit came with new terminal pins for the connectors, I had to crimp those on myself. I didn't have the right tool, went to the dealership and they let me use theirs while standing at the counter. Pretty sure I found them on the Bay, but it was about 10 years ago. Good luck.
Old May 14, 2019 | 01:25 PM
Mountainkowboy's Avatar
Mountainkowboy
Early Sporty switches are the plain ones with just the 3 buttons.
Old Oct 1, 2019 | 01:03 PM
TexNorth's Avatar
TexNorth
If anyone else does this. Don't forget you will need new pop in type throttle cables instead of the older screw in types. I figured this out on a Saturday, fortunately my local indy had cables in stock that I could use.
Other than that, it took a while to run back and forth from the schematic to real life and figure out what went where.
Old Oct 1, 2019 | 01:20 PM
Racepres's Avatar
Racepres
Lucky you gots an Indy...
Wondering why Newer handlebar controls instead of the New switch/wires solution offered by Architect???
Old Oct 1, 2019 | 02:10 PM
TexNorth's Avatar
TexNorth
I wanted the buttons so that the horn was on the outside. The older style puts the horn to the right of the high beam switch. Not to mention the turn signals are kind of recessed compared to the newer style.
Old Oct 1, 2019 | 02:20 PM
Racepres's Avatar
Racepres
All what yer used to I guess... I'm most comfortable with the '73 to '81 Type... so the '82 to ?? I don't remember '96 or something, suit me...
while the Later switch housing do Not suit me...
