Super E Question
Old Aug 22, 2019 | 10:07 AM
flhchaz's Avatar
flhchaz
Default Super E Question
Hello Folks. My 97 FLHT that has a new Super E Carb. Starts and runs great until it gets hot, then needs the enrichner pulled to keep running. I was careful installing the manifold with the intake gaskets from S&S (blue) . Could a leak in the vacuum line to the VOES cause this? I know I need to check for an intake leak, but I can't see how it would be leaking
Thanks
Old Aug 22, 2019 | 10:36 AM
Scarydog's Avatar
Scarydog
Do the wd40 or beaklean check on the seals and fittings. Everything may seem fine when tge motor is cold but aluminum grows a lot and may cause the leak then.
Old Aug 22, 2019 | 10:43 AM
Racepres's Avatar
Racepres
And... How are you supporting the Carb??? via the Top Breathers I hope..
Old Aug 22, 2019 | 10:52 AM
flhchaz's Avatar
flhchaz
Yes. The top Breather bolts. The carb is installed with the S&S install kit
Old Aug 22, 2019 | 10:57 AM
Racepres's Avatar
Racepres
Symptoms sure seem bass-ackwards... lean to start and rich to run???
Head scratcher there....
Old Aug 22, 2019 | 11:43 AM
Dr.Hess's Avatar
Dr.Hess
Did it ever run right? And "pull the enricher to keep running", do you mean to keep idling or to run at speed?
Old Aug 22, 2019 | 02:45 PM
flhchaz's Avatar
flhchaz
Sorry, Busy day at work. The bike starts right up with the enrichner on. Will idle and run strong with the enrichner off, until it gets hot, then starts to cough and dies. Wont start again til it cools down some. If I catch it before it stalls, it will run and idle with the enrichner lever pulled up 1/4 of the way.
I've checked the cam position sensor and it is not melted or leaking. The only thing I changed was the carb, so that's why I am thinking that's the issue.
Never ran quite right since I put it together, but it wasn't stalling at first. I have the carb set to the factory settings with e 295 and 72. This isn't my first Super E, just first on this bike
Old Aug 22, 2019 | 05:53 PM
Dr.Hess's Avatar
Dr.Hess
Try one richer on the intermediate and see how it changes.
Old Aug 22, 2019 | 08:34 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Seeing as how the S&S E is bolted to the intake the top breathers are not important.
Old Aug 22, 2019 | 08:52 PM
flhchaz's Avatar
flhchaz
The carb is bolted to the manifold and the backing plate is bolted to the breather bolts. I’ll take any suggestions. I’ll hopefully get into it this weekend. Seems like I never have time to work on my own stuff.....
