I'm not being a smart ***. I've read on this forum that many guys have either fond memories of their Evo or still have it and will never get rid of it. Myself, I've only had one. It was a used police bike that I got hosed on thru eBay, and I didn't keep it long at all. So I don't remember much about it other than the bad parts. Since then, every Harley I've had has been a Twin Cam. So you Evo guys, what makes the Evo so special?
I like the twin cams, I think the look of the engine is a bit different with the larger cam cone and raised deck.
The only knock on the TCs that I know of is the amount of heat they throw off.
My ‘97 Evo does everything I need it to do and does it well, I know it, parts are available when needed... I don’t have a reason to change, yet anyway.
For me its old enough to be a classic(im a 1990, bikes a 1996) yet its new enough that i could put more miles without worrying about failure like if i had a shovel. The evo still sounds to me like what a Harley should. Parts are plentyful and its cheaper to keep going 100k miles than a shovel or pan would be. Ive had my superglide just under a decade and its not going anywhere. For me i like having something newer like the tiger but then having my old carbed evo for all the memories of riding with brothers who arent alive still... there have been friends who helped me work on it and i will always cherish those memories.
Easy to work on, plentiful in the parts department, inexpensive to repair and maintain, infinitely rebuild-able, good solid reliable platform.
Not a tire shredder, but can be if you want it to, usually a cam, carb rejet, air cleaner, and pipes is all it takes to make it run and feel "respectable".
Something about the sound also. I like the sound of the evo's better than the twinkies. YD
For me its the sound and the reputation for it being a solid engine. I had a 2011 RK which I loved but felt I would eventually end up with a tensioner issue, crank runout and a transmission problem not to mention an ABS HCU failure that would be almost inevitable. Those cons combined with depreciation it was an easy decision to dump it and get an Evo but I grabbed an FXR Evo because they handle great. I think its the best all around bike Ive had.
I look at Evos as kinda the Small Block Chevy of the Harley world.
You can get parts for the other series but you can get everything for the Evos.
Hot rod mods are pretty well known.
You won't make a ton of power, but you can have a lot of fun with them.
They came with carbs and simple ignition systems.
Strong stable bottom ends.
They are that old 70's camaro. Fun, easy to wrench on, You can run it pretty good. Very few weak links (primary is the cam bearing, a $8 part).
I bought mine because I used to wrench/tinker with old muscle cars. Well, I can't afford an old muscle car nor do I really have room for one. So I got 1992 FLH and I get to tinker again without breaking the bank. And when I'm done, I get to rip around on it as well.......
I had mine for 25 years and 223,000 miles and it still ran like a fine watch to the day a careless driver wrecked it.
I’ve moved on to an M8 Softail, but, to me, the Evo will always remind me of what a Harley-Davidson should be, solid, dependable, simple to work on, classic style and endlessly rebuildable. The M8, while arguably a better motorcycle in every respect (faster, better handling, more features and technology), feels and looks more like a generic Asian cruiser than it does a Harley-Davidson.
everything stated before me. also the Evo is a better performance platform to start from, bolt together cranks instead of pressed on crank that fail with any kind of power added to it.. one cam is all you need, less moving parts to fix and cheaper to replace. when looking for a performance engine "most" are based on the Evo style, very few are Twin cam builds... yes you can build a Twinky to perform and last but it takes much more machine work and that means money! ......
you can find a late 90's Evo bike of just about any style for 5-8K, sometimes less...
