CVP Performance Needle
Old Sep 16, 2019 | 03:28 PM
t150vej's Avatar
t150vej
Default CVP Performance Needle
I'll spare everyone my reasons for asking but has anyone here tried their "Velocity Needle"?
NOT the mixture screw - the needle.
And, what needle did you replace with it?
What did it change? (best you can tell)
And what bike/mods were you running when you did it?
Old Sep 16, 2019 | 03:46 PM
0maha's Avatar
0maha
I've got the CVP needle and emulsion tube.
(And jets, and their EZ-just pilot screw thingy.)
AFAIK, the needle I removed was the stocker.
What did it change? No telling. I worked over a previously untouched carb, so made lots of changes at the same time.
That said, I'm really happy with everything. My bike (the ElectraGlide) runs beautifully.
Old Sep 16, 2019 | 04:21 PM
t150vej's Avatar
t150vej
Originally Posted by 0maha
AFAIK, the needle I removed was the stocker.........
Thanks Omaha.
Hate to plead ignorant but I don't go to town much and not good with acronyms, so what's AFAIK?
(kinda looking for needle numbers like N65c/N72s/N8NN etc)
Old Sep 16, 2019 | 04:30 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by t150vej
Thanks Omaha.
As Far As I Know
Old Sep 16, 2019 | 04:32 PM
texashillcountry
Dirt don't hurt
If you have trouble with acronyms just search google and you can usually find the answer.
That's what I do when I run across one I don't recognize.
Old Sep 16, 2019 | 05:57 PM
Kabear's Avatar
Kabear
Use the EZ adjust needle on the wife's '85 FXEF and it works fine there, didn't change a thing except made it easier to adjust.
Tried one in '01 FXDXT and it didn't work out to well, had to go back to the OEM needle to be able to adjust it.
Both carbs are CV's , with the '85 being the "Screaming Eagle" one for that year. I think that it is the first year of the CV which came out later. On the '01 it is the stock CV for that year I think, original carb was stolen at the dealership and a "trashed" replacement was put on the bike.(This story is a long one and includes at least open heart surgery)
Also use the CVP emulsion tube, but had to use a 1/4*20 tap to be able to seat the CVP jets so that the needle would seat properly. Also run their slide which comes with an attached diaphragm.
In reality I have nothing bad to say about the CVP products and would use them again if the occasion ever came up.
Old Sep 16, 2019 | 06:01 PM
t150vej's Avatar
t150vej
I usually try to avoid admitting my own ignorance but "if the shoe fits..."
Reckon I wasn't smart 'nuff to google, but I learn something everyday
Old Sep 16, 2019 | 06:08 PM
t150vej's Avatar
t150vej
Originally Posted by Kabear
Also use the CVP emulsion tube, but had to use a 1/4*20 tap to be able to seat the CVP jets so that the needle would seat properly.....
The tubes are supposed to be the same as OEM and the jets wouldn't bottom out in the tube?
Old Sep 16, 2019 | 09:36 PM
Kabear's Avatar
Kabear
Nope! They would not. Once I tapped them in they worked fine.
I really don't know if this was a one time thing or not, didn't call or even contact them about it. Just to easy to fix and move on.
The other thing I had to do was put the OEM spring back in to slow down the slide, There wasn't anything wrong with the action of the CVP spring it just didn't agree with the Twin Cams personality for some odd reason. Plus I was looking for mpg's and not performance enhancement, since I use the bikes for long trips instead of street light racing.
The EZ adjust needle would not give me enough control over the low speed jet, and low speed is what I wanted, again on the Twin Cam.
Old Sep 17, 2019 | 06:05 AM
Mattbastard's Avatar
Mattbastard
I'd like to know the difference between their Velocity Needle and the N65C that is OEM on the 88 Sportster.
