Cracked bearing
Old Oct 8, 2019 | 05:26 PM
glidein wide's Avatar
glidein wide
Originally Posted by Yankee Dog
I went with the baker bearing this past spring. About 4000 miles, bearing is fine, seal is starting to weep (it's primary oil, not tranny oil).
It's a 6205 bearing with the inner diameter of the race honed out a little (brake cylinder hone) to slip on the shaft. I can't remember the shaft diameter dimension. It's a single row ball bearing. 25 x 52 x 15 mm in size
The All ***** is a 5205 double row ball bearing with the inner honed out slightly to slip on shaft also. It is 25 x 52 x 20.6 mm in size.
The all ***** seal is a 1.125 x 1.781 x .31 (inches) or 25 x 52 x 8 (mm)
The baker bearing uses both snap rings in the primary like the stock IPB bearing, the all ***** only uses the snap ring in the primary that is closest to the transmission, it does not use the inner snap ring that is closest to the clutch. The all ***** bearing is wider so the clutch side snap ring can't be used.
I'm going to give the 5205 a try this winter when I replace the weeping seal and some other transmission parts.
I think the old shovel heads (or maybe earlier) used the 6205 slip on bearing before they came out with the press on inner primary race style. YD
Thanks for the info, no snap ring or groove for it, bearing seats in. My double lip seal never leaks, will be installing a new same.
Old Jan 5, 2020 | 11:03 AM
glidein wide
So I popped out the bearing today and it was cracked more than I thought.
Old Jan 5, 2020 | 11:08 AM
maugusta1's Avatar
maugusta1
Please keep us updated. I am learning so much from everyone post. THANK you everyone
Old Jan 5, 2020 | 11:19 AM
glidein wide
As the clutch hub bearing was starting to wear ,it caused this reinforcement washer to start riding on the inner primary bearing causing it to crack.
Old Jan 5, 2020 | 03:50 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I don`t think the washer riding against the bearing would cause a crack.
I`m thinking somebody froze that bearing and tapped it into the case (in the jet engine world, we never freeze a bearing, but we do heat the support that the bearing fits into, in this case the primary case could be heated to make it easier to install the bearing).
Old Jan 5, 2020 | 06:15 PM
TwiZted Biker's Avatar
TwiZted Biker
I'm seeing a misalignment radial loading failure with that bearing, washer digging in was a result not the cause. Question is why and how now, severe sudden shock will do it, somebody beat it in with a punch,this could crack or misalign it in the bore, mainshaft has a wahoo but there'd been big vibration with that one, lastely castings are out somehow. Or just maybe a bad bearing, not common but does pop up occasionally.
Old Jan 6, 2020 | 05:22 AM
glidein wide
This old bearing was installed by me four years ago, no freezing or heating anything, simple press fit. But it is gouged up from the washer real bad and discoloration from heat.
Old Jan 6, 2020 | 08:55 AM
TexNorth's Avatar
TexNorth
One guess is that the rubbing may have heated one side of the race more than the other and it built up stresses until a crack formed, and then the rest of the story. No proof, just a thought.
Old Jan 6, 2020 | 09:08 AM
TwiZted Biker
Memory serves me there were two variations of that reinforcing washer but off hand can't remember what the differences were, think I still have a couple in my stuff somewhere.
Old Jan 6, 2020 | 11:10 AM
glidein wide
do you know if that washer should be a snug fit when it goes back on
