Turn signal issue
is there a way to rule out the turn signal module? Thanks!
But! Since it isn't then the problem is (and this is just a guess) in the wiring of the right side. Remember the front and rear lights are connected. Also the blinker works by grounding not by sending volts to the bulb, which you may check also.
Look for a short on the right side. Bad bulb, bad socket, bad socket to ground (front or back), bad ground between the directional location(fender light bracket etc).
BTW: It is a simple system so if you can read a wiring diagram you should be able to figure it out. If I remember correctly (maybe not) wires of interest will be Orange, Purple, Brown and Red. Brown should be right, Purple(violet) should be left, Red is hot and Orange should be the runner(could be blue)
Good luck.
This bike does not use the old signal flasher system...It uses a turn signal module.
The module can fail completely, or become intermittent, even on just one side.
The old flasher system worked by switching the ground side of the circuit, but this is not the old system...
The flasher does not work by grounding, it sends voltage into the circuit, which obviously then goes to ground after it passes through the bulb.
is it possible with the module, that my turn signal ground connection is not solid on that side, could that cause the light to shine solid?
Ive been really interested in the m.unit. I may use this as an excuse to try it out.
Make up a short jumper wire.
Unplug the turn signal module.
Turn ignition switch on.
Note: In the following test, the signal lamps will not flash, they will just burn steady...
In the harness connector (that you just unplugged from the turn signal module), connect the orange wire to the brown wire (using the jumper wire), the R/H signal lamps should illuminate.
Connect the orange wire to the Violet wire (using the jumper wire), the L/H signal lamps should illuminate.
Connect the white/brown wire to the brown wire (using the jumper wire), press the R/H turn signal button, the R/H signal lamps should illuminate.
Connect the white/violet wire to the violet wire(using the jumper wire) , press the L/H turn signal button, the L/H signal should illuminate.
If the signal lights work for these tests, it tells you all the electrical circuits and the switches are operating properly, the only thing left is the Turn Signal Module, all you can do with the module is inspect the connections to make sure they are in good condition...
