Boosting up my evo
Old Oct 22, 2019 | 05:09 PM
Drifter64d's Avatar
Drifter64d
4th Gear
Default Boosting up my evo
Have a 1993 fatboy evo. Complete stock. Had some issues with the cv carb. Looking to boost the power up on it an since I got new bassani true duels that I am about to install. I figured to either get a s&s super e or just re build the cv and get thunderjets for it. Any suggestions
Old Oct 22, 2019 | 05:33 PM
Racepres's Avatar
Racepres
Carb and Pipes are Not the way to real horsepower... Sorry... Only Compression, or certainly, Cubes, will make any real horsepower.. and the Stock exhaust with free flowing mufflers as well as that CV carb are capable of feeding a fairly Hungry engine..
Remember when if ya bought all of the Gas saving gadgets available at JC Whitney... your car should actually be Making Gasoline!!!!!
Best yer gonna do is spend the maximum percentage of Funds for the least percentage of HP increase..
Old Oct 22, 2019 | 06:15 PM
Drifter64d's Avatar
Drifter64d
4th Gear
Default Ok let’s ask one more time
Ok let’s ask the question one more time any suggestions on power gains through either rebuilding my cv and adding thunderjets or getting a s&s carb. Need suggestions
Old Oct 22, 2019 | 06:32 PM
BigMike67's Avatar
BigMike67
well i hate to tell ya but Racepres told you exactly what you need to do to get power gains
pipes and carbs only help once you have cam and head work, you could do a cam swap (EV27 or 13) and get power without head work. and not even have to get a new carb or exhaust.. rebuilding the CV will help it run better but not much more power.
Old Oct 22, 2019 | 06:38 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Don`t waste your money or effort with aftermarket gizmos for the CV carb, just jet it correctly and it will do everything you need with 80 cubes under the hood.
I`m getting ready to rebuild my CV carb from my old Softail (runs like it has some crud in it at low power), I`ll shoot some pics tomorrow.
Old Oct 22, 2019 | 06:41 PM
Racepres's Avatar
Racepres
^^ Well a cam may get some folks where they are lookin to go... but, in general, not without increasing RPM to the point an ignition system is needed... More RPM can equal some small bit more horsepower.. I'll sit here and bet in regards to Real, measureable Horsepower... just a change in Pipes to that Bassani will Reduce... not gain...while a Different Carburetor... Any Carburetor; will result in zero gain...assuming the one removed [the CV] was tuned Properly in the first place..
But... If you don't actually measure the gain/loss in some way... You will smile more if you spend the money, because it will sound fast, and obviously look very Fast..
Everyone knows the S&S carb is superior to any/all...possibly excepting the Mikuni HSR... which may cost just a bit more also!!!
At Least the proper HSR will Not hinder performance!!!
I'll slip out the back door now... so the proponents of "Spend big to get big" can help you spend yer money...
Excellent advice... do Not fall for the JC Whitney Advertising of Miracle Gizmos!!!!
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Put a cam in it for some real seat of the pants results.
If it were my bike I'd put an EV-13, the S&S E carb, and the Bassani Pipes on it.
Only reason I'd change the pipes is I don't like the crossover on the stock pipes that covers the motor.
You won't gain much but what you do gain will put a smile on your mouth!!!!!
Old Oct 22, 2019 | 07:18 PM
Since 1968's Avatar
Since 1968
Many years ago I spoke with the owner of HeadQuarters at length. He advised me of two things about my Evo. He had done substantial dyno work and had never seen anything give better results than the stock headers complete with the cross-over pipe, coupled with just about any free flowing slip-on exhaust. The second thing he said was that Evo's really respond well to increased compression. His head job included shaving .070" and a corresponding skim of the intake manifold to compensate for the reduced height.
I shipped him my heads and manifold for his treatment, and added a set of Cycle Shack side dumps. I spent several weeks doing plug chops and dialing in the CV carb, and I took the time to index the spark plugs. The next year I paid for a dyno run at a bike rally. The dyno operator asked me what cam I was running. I told him it was stock and he insisted that the previous owner must have changed the cam. I insisted that I was the original owner and the cam was factory. He advised that he had never seen better numbers from a 'stock' Evo. His machine showed I had 69hp and I wish I could remember the peak torque. I sold the bike to my son and he has the dyno sheet. He had a failed lifter at 90k miles and it impaired the stock cam. This past winter he went with an EV-27 and his butt dyno shows it's running very well, maybe a bit stronger but never measured objectively.
My suggestion for applying the 80-20 rule to your Evo is to live with the CV carb, consider shaving the heads and consider keeping the stock headers. If you prefer the look of the Bassani's well why not, it's your bike to enjoy! Just thought I'd share some ancient history.
Old Oct 22, 2019 | 07:48 PM
texashillcountry
Dirt don't hurt
Jerry Branch said the same thing in the book he wrote.
Old Oct 22, 2019 | 07:57 PM
Rsbenden's Avatar
Rsbenden
I just did a cam lifters and a programable ingition,w/a stealth S&S super E shorty, Its a very nice bump up. Love to have that Basinni exhaust to finish it right,I've got baffled Longshots on it. I'm content for the moment,be careful what you wish for cuz it's like crack. Once you get a taste ya want more.
