Thanks very much for all the input. I guess my next question is how to get a Harley service manual for that bike. It didnt come with an owners manual.
I have three of Harleys finest and use conventional dyno oils in all three, except my S&S Evo. While that does use synthetic oil I wouldn't use synth in any of the others. H-D oils are just fine - also solves the problem of which of the zillions of the other brands to use as an alternative!
Everyone likes different kinds of oils, Most all are good as long as they are Motor cycle oils. If your bike has been using synthetic oil continue to use it, if not using synthetics may cause a leak around the heads. That said I use mobil1 20-50 Bell ray 85-140 trans. and Harley primary oil. Like I said everyone like something different. When your not sure Harley oils are good too.
I road raced as a kid for several years. Started in 85.
Was then! And only then that I became aware of synthetic lubes. And used them exclusively through out every component that required lube based off the recommendation of the more experienced racers. Some were pro. Guys that raced on factory works machines were passing the info down to us. Yeah! Synthetic. It does your motor good.
