Compression test
Old Jan 2, 2020 | 01:51 PM
1fastdude's Avatar
1fastdude
Default Compression test
What would be a good compression number for a 1994 Road King FLHR with 57,000 miles? Just wanted to know to see if when I put a new cam, lifters, push rods, S and S carb in, if I should do head work and possibly hone the cylinders.
Old Jan 2, 2020 | 02:01 PM
0maha's Avatar
0maha
Nice fresh battery, air filter off, throttle at 100%, lift up the slide on the carb...do all that, and you should see at least 135 to 150 pounds.
Old Jan 2, 2020 | 07:54 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Yup, as Omaha said but I would definitely do it before you take anything apart to get a base line and then post back on what cam you want to do and we'll give you some more pointers on how to maximize your upgrade..
Old Jan 3, 2020 | 05:34 AM
1fastdude's Avatar
1fastdude
OK, Thanks for all the input.
Old Jan 4, 2020 | 07:29 AM
1997bagger's Avatar
1997bagger
These guys will take care of you and I'm in your area if something just doesn't look right.
Old Jan 4, 2020 | 08:42 AM
WP50's Avatar
WP50
If your numbers are on the low side a Leak Down test is a good thing to do.
WP
hdrider53
Exhaust System Topics
Nov 10, 2021 07:27 AM
Sarhan
Engine Mechanical Topics
Oct 17, 2016 12:11 PM
trnewman
May 14, 2013 03:53 AM
ReapersWG
EVO
Oct 20, 2012 03:50 PM
kburks
11
Feb 23, 2005 01:03 AM
