Cams
Being a 1996, it came with the inferior INA bearing which is fine with a stock cam, but won't hold up to a high lift/fast ramp "performance" cam. I honestly don't remember when HD started offering the "expanded" line of SE cams, late '90's maybe (?). If I had to guess, based on the assumption a dealer installed a performance cam circa 1994 I'd say it's likely SE-1. But as mentioned, there's no way to know which cam/bearing was used without taking it apart.
My bike was 1.5 years old with about 12.5k miles and the dealer had installed the SE1 for the original owner. I pulled it out about 46K and it was shot as well as the bearing (B138). I bought a new one, discounted at a dealer, changed the bearing and pulled it about 15K later. Bearing good, hard surface flaking. Bought a used one, thinking it was "tried and true" and ran it about 20k. The bearing was still good but the cam flaking. After that, I went thru a couple summers swapping cams, lifters and push rods about every 5k, experimenting to find something that suited me. I changed at least 6 cams over that time and only changed the bearing one time - no issues. Once settled on one I liked, new bearing that I ran till I split the cases some years ago. Long and short, the B-138 is as dependable as it gets.
Most regulars here know I generally avoid opinion responses but here goes... I've run several brands of lifters over the years and for my money, the OEM 18523-86B is as good as anything out there. Any fully adjustable push rod can, and most often will, lend itself to increased valve train noise. Makes it super easy to do a cam swap though. So far as "which cam" I will only say, the SE1 is sick in a hard pull, heavy and loaded but good over 3500rpm. For a "basically" stock bike - you need lift for low rpm power and duration for high rpms. I've zero experience with S&S carbs, but a CV will not let you over throttle it by design which is good for heavy/pulling/mountain riding and once dialed in, will get you as good fuel mileage and as much power as anything I know of.
Anything(s) you do concerning carb, cam, compression, back pressure has an overlapping effect on everything else and in the end, a compromise of power and mileage that suits you and your bike/riding style is the only thing that really matters
18523-86B
But the current price for OEM Evo lifters is equal to a set of S&S Premium lifters.
The best lifter deal in town for quality lifters is Johnson HY Lift from WFO Larry (Larry`s Motorcycle Machine).
